347 Engine builder problems?
I blew the engine in my 01 ss about a month ago...
Im on a tight budget so I bought a 71k ls1 out of a friends car.
I took the engine to my friend who used to work at CBM for over 8 years as an engine builder. He told me to get new piston rings and gaskets. He tore out the engine and found out the engine still has cross hatching on the cylinders and all the bearings are cherry. He said they engine was in mint condition.
He told me I will be able to use the cam and the main and rod bearings from the engine becuase they are in very good condition. So he is going to swap my dual springs and hardened pushrods into the new ls1 and my ls2 timing chain, torquer v2 and the ls6 intake, do a valvejob, slight hone, install new piston rings new gaskets, tr55 sparkplugs, msd wires,and slp smooth bellows and reuse everything else...
Will this cause any problems?
Ps this guy was worked at cbm building motors for 8 years.. Hes reusing these parts becuase of my tight budget, being that i am a college student.... But is there anything else i shold be doing that I can afford that i should be doing?
Exactly... As you get older you are going to learn that there is nothing as streetable, well mannered, and maintance easy as bone stock. Some people will jump in here and say "Well my car is a daily blah blah blah", but if you look at the results on average a stock engined car is going to be more reliable and easier on your wallet than one that is cammed up. Hotrodding definately has it's place, but IMO hotrodding has no business being done on a car that is a daily and being in a financial pinch.
I tried to hotrod my DD many many years ago when I was a teenager. I ended up working on the thing all the time. I finally figured out to start driving it right and build a seperate hotrod. OP, if you're on a tight budget, don't hotrod your car. It has to be dependable and won't be if you drive the **** out of it.
Good point.... Kinda wish I would have seen something like that before I got the mod bug.
Now oh well.... I guess ill have to drive my crappy *** 2nd car for a week longer...
I have two cars =)
But honestly... I dont want the car to be a burden or a money pit.. I didnt think going cammed would be such an issue.
I just went ahead and trusted my gut and ordered the main bearings and rod bearings and ls6 oil pump.
Im pretty much done with it at this point...
New wires, spark plugs, ls6 intake, cam, piston rings, and all new gaskets, double springs, hardened pushrods... Im hoping the engine lasts for alteast another 50k atleast.
This is why I picked up a 70k mile engine and had it rebuild by a former cbm head engine builder.
My dailey driver just turned 250,000 miles heads, cam and all the bolt ons. It makes 452/418 and is still running strong and reliable day in and day out. You did not have to rebuild that 71K mile motor. These LS series engines will last a real long time if they are maintained properly. Mine uses a half quart of oil every 2,500 miles and I have changed the oil and filter every 5,000 miles since it was new. Spend your money more wisely in the future. As I said before a rebuild was not nessary. As a refference for you at 225,000 miles I had the heads offf of mine and you could still see cross hatching on the cylinder walls. Since you have it torn all the way down replacing the bearings is the only way to go. I'd go ahead and install some after market rod bolts while you at it that is the only real weak spot in the bottom end of a LS series engine. The rest is pretty bullit proof. Good luck with your rebuild.
I got new bearings all around... Im not doing the rod bolts becuase Ive read many different places on the forums.. that for a stock sub 450 hp ls1 with no power adders it wouldnt be a concern... other things would let go before the rod bolts stretched enough to allow the bearing to demolish itself..
The engine builder is my friend... I bought the engine from a (stranger) on ls1 tech. Seeing as I just bought a car that " Was A1" and promised to be cherry AND checked out at a well known ls1 shop blow the hell up. Im being very careful...
And school does take a while to finish, luckily im done in a year or so... Its annoying. I go to cal poly pomona and im a double major...
