Lunati Rods
Lunati Rods
Lunati part number 70361251-8
Thinking about using these in my build. Plan of Procharging it next year and looking for close to 900. Thoughts? Opinions?
I highly support Made in USA. They are built as well as inspected here in the USA. I would recommend them over Callies Compstar and also Eagle, but still believe Callies' USA product line has much more detail and consideration put into the engineering of the rod itself. There are a few fine details that Callies has taken into consideration as far as rod reinforcement is concerned that i do not see in other manufacturers until you step up to Oliver rods or similar.
I am designing a 540BBC NA with two stages and had the same idea for H beams pushing close to the same power - 1100HP. In the end i ended up with all Callies products for the bottom end.
