best cam only
best cam only
in a process of buying a cam kit from kaltech performance . Has any
One tried there products. Iam welling to get the cam to be
Shipped to over see,s
Ian planning to installs it in a full bolts on stock 99Camaro
Ls1 engine.the engine is stock. I chose there 224/230/.609 .604 113 with 7.400
Pushups And 5/16 width. And a patriot extreme valve spring. Now they
Claim that this kit is able to make 400+ whp . I was wondering if this sounds right.
Thanx
Thanx
They claim it will make between 365who to 400 my question is there any betr cam or a
Campuses known Cam that could make such whp with a stoke last motor with
Full bolts on on a 99,Camaro.
Well, you know you'll have to get it tune after the cam install so why don't you go to the shop that will do your tune and talk to them, I would also suggest doing a lot more research so you have a better understanding of what you want/need to reach your goals. This way you'll greatly increase you odds of getting what you really want.
