Help with some main bearings questions
2002 5.3L and I have a set of King OEM bearings part # MB5293SI std size. I measured them with a dial bore gauge and only have between .0005 - .0010 clearance on all my mains. So i'm thinking of getting .0010 undersized bearings or should I get a set of .002 undersize and mix/match to get the right size?
Moderator
You don't want to polish the crank to get your clearance, it will leave the journals egg shaped and tapered. They'll look pretty though.
If I were you, I'd keep the STD bearings and have the crank turned to get the clearance you want. That will ensure the journals are straight and round and it's cheaper than buying new main bearings. Also, if you're scoring the bearings with the fingers on the dial bore gauge, you may want to set it up with less preload.
How did these bearings work out for you? I'm about to buy a set off ebay, pretty cheap. Summits description says they offer additional oil clearance, but you say they were tight? We're you using a new crank, or used oem?
I just need a std bearing...
Buying undersized bearings isn't going to give you more clearance - it gives you less. Undersize means the bearing shells themselves are thicker to compensate for situations where you have crank wear or are running a ground (undersized) crank. based on what you said your measurements were your crank is "oversized" for the standard clearance bearings and as KCS said you need to have your crank ground to increase that clearance.
