what kind of push rods and valve springs should i use
Old 08-23-2012, 05:10 PM
therd27's Avatar
Default what kind of push rods and valve springs should i use
Alright so im about to purchase an LS1 with a ms4 cam in it and cant decide what pushrods and valve springs i should use with the stock heads on it now but i might get a set of LS6 heads for the bigger cam idk yet
Old 08-23-2012, 05:20 PM
Grr
Grr's Avatar
brian tooley racing springs
any decent pushrod, comp, trickflow, whatever for the length you need
Old 08-23-2012, 05:32 PM
Darkman's Avatar
The Texas Speed website indicates that the MS4 requires valve springs with 450-470 pounds of open spring pressure. If that is actually the case, I would not run oem rockers, nor would I run stock size hardened pushrods.
Old 08-23-2012, 06:59 PM
garygnu's Avatar
get the valve springs and push rods from Texas Speed.you should get a rocker arm trunnion bearing upgrade kit also.id the cam already in the motor ?thats a big cam for a stock ls1.
Old 08-24-2012, 12:16 AM
Brian Tooley Racing's Avatar
My Platinum springs are the most stock rocker friendly springs available. I also have genuine USA made Trend pushrods and the Comp trunnion kit in stock, it's all on my website.
Like was posted above, springs with 450 lbs open pressure combined with stock rockers will chew up valve tips in a year of daily driving. My Max Pressure springs are 450 lbs open but I only recommend them with roller rockers, larger than 5/16" pushrods would be needed also.
