cam and spring question
Old 08-25-2012, 12:39 PM
chevybayboy's Avatar
Default cam and spring question
How much is to much for .600 single beehive say I have pack 1218 max lift is .600 with a torquer v2 cam thats rated .595 .598 would that be to much for thoses springs
Old 08-25-2012, 12:48 PM
Sales1@Texas-speed's Avatar
I would recommend you purchase our PRC .650 dual spring kit along with the Torquer
V2. While there is people who have done this before I prefer going ahead and stepping up to our .650 spring kit for use with the Torquer V2 that is so close to that
.600 lift mark.
Old 08-25-2012, 01:09 PM
.600 lift mark.
Ok I already have cam got it pretty cheap new.. Just need springs how much are the springs you mentioned and with that torquer do you recommend degreeing that cam or lining dot to dot
Old 08-25-2012, 01:24 PM
If possible its always a good idea to degree the camshaft just to verify everything is correct, but the very large majority of people simply install the cam dot to dot. I have listed a link below to our PRC .650 dual spring kit.
http://www.texas-speed.com/p-474-pre...pring-kit.aspx
Old 08-25-2012, 01:52 PM
Thanks alot Bud
Old 08-25-2012, 01:56 PM
No problem man anytime!
Old 08-25-2012, 03:36 PM
PREDATOR-Z's Avatar
I've run this same cam on the street for nearly 2 years with Comp 918s. No issues.
Old 08-25-2012, 05:21 PM
do you perfer single beehive over the duals? Ive seen alot of dual spings horrorhorror storys
Old 08-25-2012, 06:32 PM
garygnu's Avatar
check out pac 1518 springs.
Old 08-25-2012, 07:06 PM
Yea I think im going to order.thoses
Old 08-25-2012, 07:51 PM
Restricted User
willyfastz's Avatar
That is deff. the better set of springs. Stay with the beehive's until you go to a stroker with a good size cam. Shim the 1518's to 1.750" and you'll be good to go.
O yeah the Pac 1518's are good for .650" also.
Old 08-25-2012, 07:52 PM
Restricted User
willyfastz's Avatar
The new Pac 1519 is an even better deal.
Old 08-25-2012, 08:24 PM
Looks like I might go with thoses lol to much to choose from ...
Old 08-25-2012, 08:29 PM
would I have to shim the 1519
Old 08-25-2012, 08:37 PM
bp m1009's Avatar
On Texas Speeds website it says the new 26918's are good for .625 max lift? I have a TV2 also and am going to buy the 26918s
http://texas-speed.com/p-415-comp-ca...set-of-16.aspx
Old 08-25-2012, 08:57 PM
When are you getting them.. I wanna know how install goes if tou shim and how easy it was to install it
Old 08-25-2012, 09:24 PM
bp m1009's Avatar
not for a while, im a poor college student
Old 08-25-2012, 09:35 PM
No worries I still dont know if im going to go with PAC or comps so it might be a month or 2 before I Start my rebuild thread
Old 08-25-2012, 10:10 PM
Sales@Tick's Avatar
If you want no worries in spring durability get a set of Brian Tooley Racing springs.
No failures on his dual platinum springs since their creation in 2005!
We do sell them also: http://www.tickperformance.com/brian...ll-ls-engines/
Old 08-26-2012, 01:20 AM
Thats for the kit? I think ill order thoses wen I order my springs
Quick Reply: cam and spring question
