plastic discs on LS1 injectors
I have a set of LS1 injectors I plan on using in a 5.3 swap. The plastic discs at the injector tips on 2 of the injectors are partially missing. Should I run them as is?.....replace the discs?......or should i just look for a used set of injectors?
I don't have a picture of my injectors, I'm refering to the orange disc at the end of the injector in the link below. One of the injectors is missing roughly 25% of the diameter of the injector. Another has a 1 mm notch out of the disc. And 2 of them have cracks.
http://www.highperformancepontiac.co.../photo_14.html
