radiator out for head swap??
Just curious if its necessary/better to taketh radiator out for basic head swap?? I started it today and stopped when I got frustrated with the hoses on the water pump.. I'm following the how-to on ls1 howto and seen its the next step but they are also doings cam swap.. this is my first time going to the inside of a motor so this is an exciting time.
No you dont have to take it or the condenser out for just the heads.
As for the hose clamps: Use a set of slip joint pliers, they work perfectly!
good luck with the heads! Just did mine and a cam swap
_matt
_matt
Yea autozone has the remote hose clamp pliers...you don't even have to be able to see the clamp, you just hook them in place and them the part you clamp is on like a 2 foot extension...these are awesome when the pliers won't fit...but wd40 really helps release the rusted clamps and the corrosion between hose and water pump...
