head gasket removal....
Old 08-28-2012, 04:15 PM
Possum Boggs's Avatar
Default head gasket removal....
whats the best and safest way to remove the excess head gasket gunk from the ls1 block,just wondering whats best for it bein aluminum,i dont wna damage anything,any info?
Old 08-28-2012, 04:29 PM
redbird555's Avatar
I used some permatex gasket dissolvent first then I scrapped off the rest gently with a razor blade just dont get too aggressive with it and you'll be fine.
Old 08-28-2012, 05:27 PM
batboy's Avatar
I used a plastic ice scraper.
Old 08-28-2012, 06:52 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I have used the gasket remover and the razor blade method. If you are gentle it won't scratch the deck and tends to work the easiest, in my opinion.
Old 08-28-2012, 07:20 PM
Ph.D. in HUBRIS
custm2500's Avatar
http://images.search.yahoo.com/image...mb=NezHsfzcI7J
Roloc disks. They have three grits, Yellow is medium I beleive and works great to clean everything with no issue.
Old 08-28-2012, 10:53 PM
wildcamaro's Avatar
^^^^^what he said, just don't use green unless it's an iron block..
Old 08-28-2012, 11:38 PM
wire brush is bad?
Old 08-29-2012, 02:34 AM
DisasterpeaceWS6's Avatar
https://ls1tech.com/forums/generatio...k-removal.html
Old 08-29-2012, 06:11 AM
MT0911's Avatar
I used a plastic ice scraper to remove the excess gasket. It works fine and you have no fear of damaging the block.
Old 08-29-2012, 11:10 AM
wildcamaro's Avatar
Roloc disc are plastic fingers so it is the fastest, safest way as long as you take your time and cover the motor appropriately
Old 08-29-2012, 11:57 AM
wildcamaro's Avatar
Old 08-29-2012, 07:03 PM
AutomagicLS1's Avatar
acetone and a plastic ice scraper
Quick Reply: head gasket removal....
