how driveable is the trex cam
Old 04-06-2004, 02:42 PM
BAD2000Z28's Avatar
Default how driveable is the trex cam
How is the driveability on the "trex" cam from thunder racing? How is it in traffic, cruising, going down the road? I no that it is not for a daily driver but how does it drive around town?
Old 04-06-2004, 04:41 PM
chrdij's Avatar
I was wondering the same thing on a A4 with a good stall that is
Old 04-06-2004, 04:50 PM
EVIL's Avatar
i only drove mine around the block and in the parking lot a little, and it seemed ok after a little tuning to get it to idle.
low end power is sloppy, but once it hit the 4000 stall, it sounded like a prostock!
Old 04-06-2004, 06:41 PM
Savageite's Avatar
Did you go with the 90mm FAST intake?
Old 04-06-2004, 06:45 PM
BIGBOS's Avatar
A friend of mine will be installing one in a 6-speed soon, I will let you know how it does
Its not gonna idle smooth at all.....I know what my X1 did when I had it, if I left the doors open it would rattle like mad
Old 04-07-2004, 02:24 AM
chrdij's Avatar
That cam sounds bad a$$, just wondering did u use Ls1 edit for the tune? I have heard some places can do a mail order on your PCM with a quick turn around time, not sure where to get it done though nor the cost. The reason Im asking is in the next week I will be placing an order on one my self.
Old 04-07-2004, 05:00 AM
EVIL's Avatar
yea, we used edit to tune it, it takes some work. i started with my tr224 tune and it didnt like that, so i went back to my stock tune and worked from there and it was better. still needs a little more work, after i get the heads back on it, i will mess with it more.
Old 04-07-2004, 07:02 AM
Super Moderator
Reckless's Avatar
I tuned an A4 over the weekend with a 4400 stall. It actually idled before tuning. I did not even drill out the TB blade. Just tweaked the lower VE table a bit and raised the idle to 850 and it idled fine. WOT tuning was easy, but the car (a 1998) has a nasty stumble at part throttle around 3000-3200 rpm. I thought it was a dirty MAF, but after cleaning it still stumbled badly. Not related to the cam though. Believe it is electrical in nature (bad coil or something).
