Max RPM for stock bottom end???
I have a 2000 LS1 that has H/C/I/E, but stock bottom end. My rev limiter is set at 6200 rpm right now. I read that some people are turning as much as 6600 on stock bottom end LS1's. I am going to get my car re-tuned soon and I was hoping that higher rpm would benefit my 228R cam. What would you set the rev limiter at? This is an LS1/A4 with 3600 stall.
I spun my max effort stock bottom end car to beyond 7000rpm for a long time, but this is definitely not recommended unless your setup requires it, and at that point you probably know the risk your taking spinning one that hard.
Shift it at 6500-6600 and set the limiter at 6800.
I like Aaron have turned mine 7200-7400rpm many times. I didn't see any gain in MPH at the track with turning it 7400rpm so I only turned it 7000-7200. I do have Katech rod bolts and a cam that really requires it though(239/247 .624/.624 110+0) so for most of the members here it's not necessary and the stock style intakes don't make peak power past 6800rpm anyways. How far it carries it past peak is another story though.
i turned 7k all the time with my stock bottom end. i didnt care if it blew a rod out the side though. it wasnt my daily driver and i wanted to build a motor anyways. you never know though. it could cut loose cruising down the road. parts break...**** happens.
We have had my wifes car shifting about 6600-6700rpm without an issue on a 150shot for the past 4 years. Popped the 6900 limiter a couple times on the street too. We have a red spring pump in it and the Tick Polluter cam other than that its a completely stock 141K mile bottom end.
1st gear set it at 6800
2nd set it at 6700
3rd and 4th set it at 6550
keep your rev limiter 5-600 over every shift point that way u wont bump into it especially if using a smaller tire on the track
2nd set it at 6700
What RPM would be ideal for the TSP 228R?
