Do you think the redesigned 26918 spring is capable of a constant .601 lift cam?
I was hearing great things about the new redesigned springs from comp. So I ordered them for my 232/238 .599"/.601" lunati cam. Do you think I'm running a weak spring for my cam? I'll only be revving the motor to 6400 if that..
It will be fine just make sure you install them at correct height.
Thanks, i've been around for awhile. I stress on install height, it should be equal on all valves. Done properly, I've never had a 918 fail on me, or any other single beehive for that matter.
Trick is attention to details and installation protocols.
