Titanium Nitride coating on valves?
I've found some googled reseults from different coating company's claiming that the Titanium Nitride (TiN) coating is virtually frictionless and works extremely well with maganese bronze guides (which i plan on using) Does anyone have any previous experiences with this coating? Would this be a worthwhile investment on both intake and exhaust valves? From what I understand it adds, durability, hardness, decreased friction, high wear resistance, and is corrosion resistant. It certainly sounds like a great product.
Any future valvetrain upgrades in your future? If not, i would recommend it as it additionally promotes resistance to detonation from hot spots on the exhaust valve face; that is where alot of heat is concentrated. Valve coatings are a viable option depending on the future upgrade plans and current wear on the valvetrain.
Ti valves use moly on the stems typically. CrN is a bit more economical and DLC on the stems works also but expensive. Moly also typically gives the best bronze guide life for the cost.
TiN is used on the valve seat on Ti valves. Keeps the seat of the valve from wearing.
