New 347. What do you guys think?
Well guys starting to get the last of my parts for my new motor tell me what you think
Diamond Forged Pistons-3.905
Diamond Rings
Crower I-beams-6.125
Federal Mogul Main Bearings
Federal Mogul Cam Bearings
Federal Mogul Rod Bearings
ARP Main Studs
Harder Performance 5.3 Stage III heads
Manley 2.02int/1.60ext
Complete Manley Valvetrain
Comp R Lifters
Ported and Plummed LS6 intake
NOS Sportsman Fogger 50-250
Compression 11.8.1
T-Rex Cam-soon
TSP Ported Oil Pump-soon
Harland Sharp 1.7 Rockers-soon
TSP Double Roller-soon
Tell me what you guys think. Hoping to get 500rwhp+ out of this N/A. Tell me what you guys think. Purchased all these parts individually and saved. These are not cheap parts either. They are quality. Couldn't find any shortblock assembled like I wanted and for what I wanted to pay. This way is way cheaper. Tell me what you guys think about it and if my 500rwhp is possible.
Take care guys
mike
Diamond Rings
ARP Main Studs
Comp R Lifters
Compression 11.8.1
T-Rex Cam-soon
Take care guys
mike
Diamond Rings
ARP Main Studs
Comp R Lifters
Compression 11.8.1
T-Rex Cam-soon
Take care guys
mike
Diamond Rings
ARP Main Studs
Comp R Lifters
Compression 11.8.1
T-Rex Cam-soon
Take care guys
mike
btw--can you send me your phone number again? I accidentally nuked my inbox.
1 Post
I'm guessing your car is a M6.. I'd have to be realistic and say that you could pump out a solid 450 RWHP with that setup and a 6 speed. Thats still some killer power, but 500 RWHP for a 347 I think you would have to go with an extreme solid roller motor. Futral laid down 520 RWHP with his insane SR 347.
If you have an A4/A3 then you expect alot lower dyno number, however that doesn't mean the car will be any slower.
Just use the Dyno to tune the car and use the 1/4 mile to measure its performance.
Good luck with the new setup, always fun to build a new motor.
Lee
Lee
It is a dream though?! LOL. No offense taken man. Yeah i will send you my number again. I was wondering why no call last night but figured you were busy. As for the power, You watch i will push that 500 plateau you just wait and see. I will change my name from 1998redcoupe to 1998redblur! i am gearing up for this summer and getting ready for our race. later man
there have been several hydrolic 346's to break the 500rwhp mark. it can be done but it won't be easy. you will need some really good heads. absolute put out a couple of them with ls6 heads that flowed 320+ cfm with a 210cc runner (they had incredible number through the intake if i remember correct as well). good luck to you and keep us updated
You guys think that i should push 450 but not 500? well i can hope cant I? I will give it an honest try though for the 500. believe me if i hit 450 at the rears that means i would have well over 500 at the fly right? I could live with that. 450? that will work cheer me on guys
Yup, you'll be over 500 at the crank with little trouble. 500 crank is 1.44hp/cubic inch. Tough, but doable with your motor. 1.5hp/ci and over you have to get exotic, either through engineering, materials, or most likely both.
Hell, if you're that optimistic what do you think my 408 solid roller/lsx/12:1cr will do?
I think it is possible too. I THINK though. I will let you all know though. At least a 450 is possible i firmly believe. 500rwhp on N/A is my goal on basically stock displacement. I have seen and heard about this being done a couple of times by big name tuners, but I am just a regular joe that is going to give this a run.
More compression and cam? I was figuring that was plenty for this motor. how much might be needed? If i hit 450+ N/A,when i hit my juice button i gaurantee i will be in the tens. THE REDBLUR will be born!! Oh yeah and my new license plate will read
either " I WIN!" or " IWNULSE"
Hey, Sounds a lot like my set up. Mine is under construction right now. Check it out, tell me what you think ill do? It will be ready soon.
LS6 block 347 C.I
Lunati 4340 Forged Crank
Lunati Pro Billet Rods
Lunati Pistons and Rings
King Bearings
ARP Rod Bolts and Main Studs
Absolute Speed Stage 2x 6.0L Heads ( around 320 cfm @ .600 )
Crane Duals, Bronze Guides, Hardend Push Rods,
TTP " Equalizer Cam Shaft" ( slightly larger then G5X2 )
11:53:1 compression ( estimated )
Absolute Speed Ported LS6 intake
Absolute Speed 78mm TB
Kooks 1 3/4 Steeped to 1 7/8 " Headers, Off Road Y, Hooker Catback
TSP lid, ASP pulley, LS1 edit, Mezeire Water Pump
Will be dyno tuned in a couple weeks on 16" tires with 3.73 gears in a 10 bolt. Saving up for the 12 bolt. Car is an M6 Z28
Will have a Nice shot on it after breaking in.
LS6 block 347 C.I
King Bearings
Originally Posted by blackLS1
What tuners have dynoed 500 with 347s?Any links to that info and the setup they ran.I would love to go this route 500RWHP NA.
I made 491 hp and 430 tq to the wheels threw a Moser 9" and 4.11 gears. I had an LS6 stock short block with ARP rod bolts. As for mods I have the Electric water pump TPIS intake and throttle body. Grott headers with a 2 1/2 inch X-Pipe exhaust. I also had the normal bolt on's ASP pulleyDirect-flo lid, stock descreen maf. The car has gone a best of 10.69@ 128.92 mph at a race weight of 3260.
So yes 500 to the wheels is possible and can be done I was running 93 octaine gas and the compression was 11.1 I belive.
good luck with your set-up I'm sure it's going to make some nice power
