stock 6.0 or 408 pump gas motor. need alot of torque and help
wanting to build pulling truck. need a motor with good torque. parts i have so far are lq9 short block 317 heads and trailblazer ss intake. I want to use all of parts listed. what comp. should i run for pump gas 93 octane. or should i run e85 with higher comp.
Posted from LS1Tech.com App for Android
Get the compression up by milling the heads, get a good port job on the 317s. Port match the manifolds bc there is plenty u can remove. If you can use any stock ex manifold I suggest c5 z06 corvette manifolds, I saw a dyno test where they matched some shorty headers. I have a set I would sell you cheap if your interested. Def keep that trailblazer ss intake for max torque.
Go with a 4" stroke no doubt.
You're going to need something way out in left field on the cam timing.
I'm not even going to attempt to try and throw a profile out there because it will be followed by 5 posts asking why does it look like that and that will never work. If you're interested in this profile shoot me a PM, E-mail or call the shop tomorrow from 8-5 EST.
