I don't think I will use an ARP Harmonic Damper Bolt again.
I used an ARP harmonic damper bolt when I installed my new ATI harmonic damper. Yesterday I had to remove it in order to advance my camshaft. It did not want to come off. I actually had to go buy the biggest baddest 1/2 impact that Ingersol Rand makes and crack my air pressure up to 130 PSI. Still it took well over a minute before it broke loose. I never had these kind of problems with the factory bolt. So, I am going to go buy a GM bolt when I put it back together tomorrow.
Anyone else experience this?
It was long enough ago that I could not remember if and what I put on the threads during installation, but when I inspected the bolt, it appeared to have a molly lube on the washer but not the threads. I am reluctant to re-install it, but I might (using the proper lube) and hope that solves the issue.
I say put the ARP lube on it and reuse the bolt.
I don't understand how people have broken these crank bolts. I've had my balancer off like 4 times now and used an ARP style bolt on mine, and have been installing the SLP/Power Bond pulleys at work on new Camaro's and haven't had many issues. Even if you pull the pulley on with an installer tool just so the bolt has like 10 threads to catch you will be just fine. I always pull it on all the way but still.
/Rant lol
/Rant lol
I had new OEMs backout after proper proceedure install. Culprit radical cam with rough idle. The cam may have lead to engine mount failures and destroying an underdrive harmonic balancer. messed up the snout on the crank to cause a rebuild. ARP bolt waiting for its return from machine shop.
The Scammer Hammer
I just torqued mine down yesterday. I don't have a torque wrench that goes that high, but with a 20" wratchet horizontally, and me standing inside the engine bay where the radiator was, I just acted like the wrench was a bar and did a dead-lift. I got at least 250ft lbs on it. No worries here.
