Getting ready to purchase Cam and others...
Old 09-18-2012, 07:35 PM
tyler99's Avatar
Default Getting ready to purchase Cam and others...
I am on TSP getting ready to order a cam for my 98 SS, and I am just wondering if im missing anything..
Texas Speed Camshaft Package w/ Dual Valve Spring Kit
SKU: 25-CamPkg2 Change This Kit
- Texas Speed Magic Stick v.4 Camshaft (111 LSA)
- 110 LSA
- PRC .650" Dual Spring Kit
- 7.400"
- Do Not Include Pushrod Length Checker
Basic Camshaft Bolt & Gasket Kit
SKU: 28-CamGskKit Change This Kit
- GM Bolt
GM LS2 & Newer Style Timing Chain
SKU: 28-12586482
Texas Speed Ported LS6 Oil Pump
SKU: 25-LS6PortedPump Change This Kit
GM Replacement LS7 Lifters
SKU: 28-12499225
GM LS2/LS3/LS7/L98 Lifter Trays
SKU: 28-12595365
That is what I have in the cart, is their anything anyone can see that I would be missing that I may want to pick up as well?
Any suggestions would be appreciated.
Thanks!
Old 09-19-2012, 12:14 PM
14k
14k's Avatar
Rod bolts
Old 09-19-2012, 12:49 PM
PREDATOR-Z's Avatar
If for street I would reconsider running such a cam. What other mods do you have.
Old 09-19-2012, 12:59 PM
Chaos07's Avatar
ya that ms4 is a turd on the low end you'll need some gears to make it run right. I would probably do a 228 or something a little bigger. Depending on your mods
Old 09-19-2012, 03:30 PM
arock24's Avatar
Depending on your application. I wouldn't go any bigger than the TSP v2 or v3, especially with stock heads. Do you have any other supporting mods?
Old 09-19-2012, 07:11 PM
garygnu's Avatar
the biggest cam is not always the fastest car.you need a big stall for that cam.it will lower your dynamic compression ratio .how many miles on the engine ?what intake and exhaust do you plan on using.
Quick Reply: Getting ready to purchase Cam and others...
