How bad does fuel mileage suffer?
Old 09-26-2012, 11:51 PM
my_99Z's Avatar
Default How bad does fuel mileage suffer?
Just a question but how much is fuel mileage affected with a cam swap? I'm looking at putting possibly a 224 or 228 cam in my DD, it's a 99 ls1 and an m6 right now with my current setup I have long tube headers, or-y, slp ram air box, and a lid. I get about 23-24 mpg with probably 70% highway and 30% city driving. I have yet to get a tune done, my main question is will I see a decrease/increase or relatively the same fuel mileage if I were do put one of the above mentioned cams in?
Old 09-27-2012, 02:23 AM
1_MEANZ28's Avatar
Not much considering u have a m6 .if u had an a4 the mpg would suffer more due to the stall ..those cams are great and aren't considered big cams
Old 09-27-2012, 03:16 AM
my_99Z's Avatar
How much would I be looking at suffering? Would a tune do anything for it?
Old 09-27-2012, 03:27 AM
my_99Z's Avatar
Only reason I'm asking is cuz it's my DD right now, looking at putting something to give me more power but also not murder my good fuel mileage as I drive around about 300 miles a week right now with school and work.
Old 09-27-2012, 09:02 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
With a 6 speed transmission, and a good tune, if you can keep your foot out of the pedal and cruise it, you should be within 1-2mpg of what you had cruising before the cam swap. Now of course when you're making more power, you're using more fuel!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-27-2012, 06:52 PM
farmington's Avatar
when I went to a 224r my city milage went from 19 to 17 but I'm probably in the throttle more now. Its probably not even worrying about. BTW I have an A4 with a 2800 converter and 3.73 gears.
Quick Reply: How bad does fuel mileage suffer?
