What ls6 heads to run with torquer v3
Old 09-29-2012, 07:20 PM
97ta383's Avatar
Default What ls6 heads to run with torquer v3
So im planning on runing a torquer v3 cam with my car (in sig) i was looking at geting either prc stage 2.5 ls6 heads or patriot stage 2 ls6 heads. The prc heads are $300 more just wondering if its worth the extra cost.
Old 09-29-2012, 07:21 PM
garygnu's Avatar
maybe look at the PRC st 1 heads with needed springs.
Old 09-29-2012, 08:39 PM
BrntWS6's Avatar
The 2.5's come with .650 lift springs which you'll need, and better valves for $100 more than the Stage 1's. I have the same setup your looking at....got a little over 100rwhp with a FAST 92 on the same dyno.
Old 09-29-2012, 08:50 PM
97ta383's Avatar
the patriots come with dual springs as well
Old 09-30-2012, 09:56 AM
BrntWS6's Avatar
I think Patriot had a bad set of castings a while back and that stuck with them as being a low quality head. I went with TSP because they help a lot on this site with members problems, but if money is tight the Patriots are probably fine. I'd just make sure they use quality valves etc, as I don't know much about them.
Old 09-30-2012, 10:47 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
I am a little biased but I definitely recommend the PRC 2.5 LS6 heads. We have put a lot of work into our LS6 port over the years and I think it shows. We can also make sure the heads are specifically milled for that cam if you want.
Quick Reply: What ls6 heads to run with torquer v3
