Why is my 5.3 crank sticking out?!?
Old 10-02-2012, 11:32 AM
4SFEDZ's Avatar
Default Why is my 5.3 crank sticking out?!?
I'm putting a 5.3 in and the end of the crank is sticking out almost an inch from the back plate
Old 10-02-2012, 11:45 AM
cause4panic's Avatar
Possible you have a long crank 6.0 and not a 5.3?
Old 10-02-2012, 11:49 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Sounds like the longer/thicker flanged 6.0L crank.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-02-2012, 12:00 PM
4SFEDZ's Avatar
Ok so I was told sometime they have a spacer that can b removed. So that's not the case? The flange is just thicker? So the crank is not usable with a t56?
Old 10-03-2012, 08:29 AM
oange ss's Avatar
you have an early long crank, cant be used with a T56
Old 10-03-2012, 08:34 AM
bww3588's Avatar
I believe it can be used with a LT1 T56 with an LT1 flywheel and pressure plate, and an LS1 disc.
correct me if I am wrong.
Old 10-04-2012, 12:20 PM
Some have a spacer, how many holes are on the flange? There is a photo of the spacer in my build thread. If two of the 8 holes are threaded from the beggining you can use two flexplate bolts to remove the spacer.
Quick Reply: Why is my 5.3 crank sticking out?!?
