wierd noise inside cam only Ls1
Old 10-02-2012, 12:46 PM
GARAGE_BUILT_Z28's Avatar
Question wierd noise inside cam only Ls1
full bolt on 100k mile Ls1 stock bottom end cam specs are 227/231 613/617 111+4 Lsa has harland sharp rocker arms non adjustable 650 lift dual springs..so far I've pulled both valve covers and the last 2 push rods on the passenger side to check if they are bent them seemed pretty straight..the car can fire right up and has excellent oil psi I run full syn mobile 1 10-40w and thoughts on this problem will help thanks.
Old 10-02-2012, 01:27 PM
sokr915's Avatar
Are all your rockers torqued down to spec?
Old 10-02-2012, 01:40 PM
Yes they are to 22FT Lbs if this noise is a lifter going bad will it sound like this also?
Old 10-03-2012, 02:12 AM
Bump for answers I see a lot of views I need some help here guys thanks..
Old 10-04-2012, 11:39 PM
MJs1FastSS's Avatar
Other than a gasket leak and my old rims in the video, its sounds to me like a lifter on its way out. Time for some ls7 lifters to suite your needs
Old 10-05-2012, 12:06 AM
I'm gonna order some prolly this week and I actually wanna go back to chrome ss stocks so I'm either gonna sale or trade these C6 wheels :-)
Old 10-05-2012, 02:27 AM
99Bluz28's Avatar
Either their straight or bent; no middle ground. Make sure you check all the PRs and rockers for damage or abnormal wear. I'd also check for a exhaust leak, especially if your gas mileage has dropped a noticeable amount. If all of that checks out fine then I clearly would say it's a bad lifter.
Old 10-05-2012, 02:46 AM
I'm in the process of checking all that stuff now...what do you think can be the cause of my headers glowing cherry red when the car idles from a cold start sometimes
Old 10-05-2012, 03:05 AM
99Bluz28's Avatar
Either it's running really lean, or the timing is being retarded a lot. Do you have any codes pop-up?
Quick Reply: wierd noise inside cam only Ls1
