swapping coil harness from 241 to 243 heads.
I'm trying v swap the swap the harness from my factory 241 heads to my 243s. Its the harness that holds the main connection for the coil packs.. I bought new coil brackets from Hawks and don't see a place to screw the bracket in for the connection... do you just not screw it into the new coil brackets and let it float ?
