oil galley plugs and camshaft end plug
Old 04-09-2004, 10:54 AM
batoutahell's Avatar
Default oil galley plugs and camshaft end plug
I have been reading through alot of posts and seen the oil galley plugs come up for different situations, but have not seen a post explaining where they should be. I have a used block, and it is my first ls1, and I am not sure if all the oil galley plugs are in or not. Is there a site that shows where they go? Or a manual?
Also in the block I have there is no plug or cover for the back of the cam to hold it in place. Is the plug a press in, like a freeze plug or is there a cover for it that bolts in place?
Any part numbers for would be great also, or where to get these things.
Is there a online microfiche anywhere so that we can look up some of these things, if not I think it is a good idea.
Thanks for any help
Old 04-09-2004, 04:56 PM
to the top
Old 04-10-2004, 11:05 AM
anyone
Old 04-10-2004, 03:56 PM
Does anyone have a helms manual that they could look in for me?
I would sure appreciate it.
Thanks
Old 04-10-2004, 04:54 PM
BigTex's Avatar
Here is a disassembled view of the LS1 for a C5:
(hope this helps)
(1) Engine Flywheel - Manual Transmission
(2) Engine Flywheel - Automatic Transmission
(3) Engine Flywheel Bolt
(4) Oil Pan Gasket
(5) Oil Pan - Upper
(6) Oil Pan Cover Gasket
(7) Oil Temperature Sensor
(8) Oil Pan Cover
(9) Oil Pan Cover Bolt
(10) Oil Pan Closeout Cover Bolt
(11) Oil Pan Closeout Cover
(12) Oil Filter Adapter
(13) Oil Filter
(14) Oil Pan - Lower - Gasket
(15) Oil Pan - Lower
(16) Oil Pan - Lower - Bolt
(17) Oil Pan Closeout Cover - Left Side
(18) Oil Level Sensor
(19) Oil Pan Closeout Cover Bolt - Right Side
(20) Crankshaft Bearing Cap Side Bolt
(21) Crankshaft Bearing Caps
(22) Crankshaft Bearing Cap Stud
(23) Crankshaft Bearing Cap Bolts
(24) Crankshaft Bearing
(25) Crankshaft Bearing - Thrust
(26) Crankshaft
(27) Crankshaft Sprocket Key
(28) Engine Block Front Oil Gallery Plug
(29) Clutch Pilot Bearing - Manual Transmission
(30) Camshaft Position Sensor Bolt
(31) Camshaft Position Sensor
(32) Oil Pressure Sensor
(33) Engine Block
(34) Piston Rings
(35) Piston and Connecting Rod Assembly
(36) Connecting Rod Bearings
(37) Connecting Rod Bearing Cap
(38) Connecting Rod Bolt
(39) Oil Pump Screen Bolt
(40) Oil Pump Screen O-ring Seal
(41) Oil Pump Screen
(42) Oil Pump Screen Nut
(43) Crankshaft Oil Deflector
(44) Balance Weight - Manual Transmission
(1) Oil Level Indicator Tube Bolt
(2) Oil Level Indicator Tube
(3) Oil Lever Indicator Tube O-ring Seal
(4) Valve Lifter Guide Bolt
(5) Valve Lifter Guide
(6) Valve Lifters
(7) Engine Block
(8) Crankshaft Rear Oil Seal
(9) Engine Rear Cover Bolt
(10) Engine Rear Cover
(11) Engine Rear Cover Gasket
(12) Engine Block Rear Oil Gallery Plug
(13) Crankshaft Sprocket
(14) Camshaft Timing Chain
(15) Oil Pump Assembly
(16) Oil Pump Bolt
(17) Engine Front Cover Gasket
(18) Engine Front Cover
(19) Crankshaft Front Oil Seal
(20) Crankshaft Balancer
(21) Crankshaft Balancer Bolt
(22) Balance Weight - Manual Transmission
(23) Engine Front Cover Bolt
(24) Camshaft
(25) Camshaft Retainer
(26) Camshaft Retainer Bolt
(27) Camshaft Sprocket
(28) Camshaft Sprocket Locating Pin
(29) Camshaft Sprocket Bolt
(30) Camshaft Bearing
(31) Water Pump
(32) Water Pump Bolt
(33) Water Pump Gasket
(34) Oil Level Indicator
Old 10-21-2005, 09:52 PM
SILVERZZ28's Avatar
Old 10-21-2005, 11:08 PM
racecar's Avatar
In the front there is the cam retainer and the gear, that's it, nothing else except the front cover. The back has the rear cover. There is not a cam plug, just the cover on the back of the block.
I bought a Corvette parts CD on Ebay for $8. It has the parts but the drawings are not nearly as clear as the ones above. BigTex, where did you get those great pictures??
Old 10-21-2005, 11:10 PM
SILVERZZ28's Avatar
the 6.0 iron blocks have front plugs I do believe
Old 10-21-2005, 11:13 PM
racecar's Avatar
Oil passage plugs, yes, there are several. I think that they are metric threads so you probably won't find that at the hardware store, I bought all of them from the Chev dealer.
Old 10-22-2005, 08:51 AM
Mr. Luos's Avatar
SDPC just sent me all my oil galley plugs and freeze plugs.
Putting them in this afternoon. #12 from those pics (bottom pic--GM #12573460) goes at the rear of the motor under the rear cover. #28 (first pic--GM #09427693) is under the front cover. Obviously.
I don't see the freeze plugs though. Coolant drain plug---GM # 12561663 and 3 oil galley sealer bolts....GM # 11588426.
4 head dowels and 2 tranny dowels as well.
Quick Reply: oil galley plugs and camshaft end plug
