TFS 215 and VRX5 results
Old 10-06-2012, 11:28 AM
stryder's Avatar
Default TFS 215 and VRX5 results
This build exceeded my expectations by far. Parts from Vengeance Racing, built by me and my buddy Matt , and tuned by Ryne at CMS. 99 FRC LS1
Trickflow 215's 59cc
VRX5 236/238 113
FAST 92MM LS2 90mm TB
Longtube Headers/High flow Catted x-pipe
TI catback
Vararam CAI
42lb injectors
Comp rocker trunion upgrade
melling high flow oil pump
25% pulley
160 tstat
I think thats it. Took the car to Ryne for a tune and Dyno I was quite surprised by the results 493whp and 428wtq. Not to bad for a little 346. Got to get it to the track to see how she really does.
Last edited by stryder; 11-01-2012 at 02:30 PM. Reason: graphs should be visable now
Old 10-06-2012, 04:45 PM
1999BlueTA's Avatar
Wow great numbers, Congrats & with traction you should have strong 1/4 mile results, MPH should be strong also GL!!!
Old 10-06-2012, 05:41 PM
stryder's Avatar
thanks, I get some DR's to hook up.
Old 10-06-2012, 06:12 PM
A.R. Shale Targa's Avatar
Real nice power for a 5.7....are those numbers SAE or STD corrected ??
I never see a Trick Flow combo thats weak.
Old 10-06-2012, 06:16 PM
c5z16z's Avatar
i always see good results from trick flow heads, and ls1 ls6 i always see the 215cc TF heads do really good, cant wait too see your results at the 1320,
what drag radial are you running and on what rear rim ?
were is your static compression at ?
how thick are the head gaskets ?
and did you have too flycut your pistons for that small of a chamber ?
i have the same cam in my c5z and cant wait to get some TF 215...
post some pics of that beast
Old 10-06-2012, 07:05 PM
stryder's Avatar
probably gonna run the Mickey Thompson ET streets, don't remember the static compression stock gm head gasket no flycutting needed. I will get some pics up soon.
Old 10-06-2012, 08:49 PM
garygnu's Avatar
great numbers ! what valve guides do you have in those heads ?
Old 10-06-2012, 09:48 PM
stryder's Avatar
I have the powdered metal valve guide option Gary
Old 10-06-2012, 10:11 PM
Sales@Tick's Avatar
Anytime I have a customer that calls in that wants these results I give him the recipe you just described.
With people saying rectangle port this, rectangle port that....if they only knew what a properly specified, simple set-up with a good cathedral port head would do on their larger cubic inch motors they would never want to even consider a rectangle port head again.
They have their place, but not on anything under 4.125" bore IMO.
Great results and I'd love to see the power curve.
Old 10-06-2012, 11:02 PM
jonisalex's Avatar
Those are some great numbers, good job!
Old 10-06-2012, 11:44 PM
98z8uup's Avatar
Those are some good numbers.
Old 10-07-2012, 03:21 AM
stryder's Avatar
Thanks Martin and the rest of you guys for your comments, I posted the Torque graph too can you guys not see them? Oh and the static compression ratio is about 11.2 dynamic is about 8.85 i think.
Old 10-07-2012, 03:50 AM
IllusionalTA's Avatar
Def strong setup, I assume its a manual?
Old 10-07-2012, 10:44 AM
stryder's Avatar
yep it is a manual
Old 10-07-2012, 12:28 PM
HCI2000SS's Avatar
Those numbers are insane! When I went to get mine dynoed a few days ago there was a LS1 WS6 with Trick Flow heads (don't know what kind) M4 cam, Fast intake, long tubes, etc...and it only made like 413 rwhp. It was a 6-speed as well with 4.10 gears. For reference mine did 405 rwhp on that same dyno
Old 10-07-2012, 02:26 PM
stryder's Avatar
the dyno i was on is a dyno dynamics load bearing dyno its a stingy one but im not to intrested in the dyno numbers i want to see what it runs on the track that what counts.
Old 10-07-2012, 02:28 PM
HCI2000SS's Avatar
Yep the track will tell the true tale
Old 10-07-2012, 02:30 PM
wildcamaro's Avatar
Damn that is a lot of power! Those Trickflow heads are awesome!
Old 10-07-2012, 02:32 PM
c5z16z's Avatar
post the graphs
Old 10-07-2012, 02:40 PM
99Bluz28's Avatar
No graph in sight...
Quick Reply: TFS 215 and VRX5 results
