Spun #1 rod bearing?
Old 10-12-2012, 08:07 PM
87DodgeD150's Avatar
Angry Spun #1 rod bearing?
I recently just put together an Ls1 with TSP stage 2.5 ported heads with an eps cam. The bottom end is fully balanced and I had clevite H series bearings.
Well it managed to spin a #1 rod bearing. I also have a melling hv oil pump.
Today I started to tear the motor down. Pulled the heads off and they looked great. Pulled out the lifter trays and come to see the #1 piston exhaust lifter roller is destroyed. These are brand new LS7 lifters I just purchased form Texas Speed. The lifter bore is in tolerance and is not damaged at all. Same with the lifter tray. We just cant understand how this lifter could be destroyed. Engine always had plenty of oil pressure. Motor almost had 1k miles on it.
There was no piston to head contact either.
A few people are leaning towards a defective lifter. I've ran into lifters that have been machined wrong. Needless to say my cam is trashed as well.
We are thinking the lifter somehow went bad, sent metal into the bottom end and ate up the #1 rod bearing. It doesnt make too much sense to spin a bearing that is the most oiled part of the entire motor.
I am going to contact Texas Speed about this and maybe they can shine some light on my problem.
Old 10-12-2012, 08:14 PM
sweet99ss's Avatar
That really sucks to hear man. Hopefully you get it all figured out
Old 10-12-2012, 08:18 PM
Me too. I'm not calling out Texas Speed saying their parts are junk either. I loved how hard the car ran and I know I will continue to buy stuff from them.
It just baffles me. I could understand if the lifter bore was making the lifter stick but it wasnt. Ill post up some pics later of the damage.
Old 10-12-2012, 08:29 PM
I posted a pic of the lifter bore that the lifter came out. Perfect shape.
You can also see the lobe on my cam that is messed up.
Attached Thumbnails Spun #1 rod bearing?-2012-10-12_20-20-33_770.jpg   Spun #1 rod bearing?-2012-10-12_20-22-12_977.jpg   Spun #1 rod bearing?-resizedimage_1350091628430.jpg
Old 10-12-2012, 09:13 PM
the_merv's Avatar
Yea this baffles me as well cause I'm the one that built the engine and it was assembled with correct specs. It ran hard during tuning and to see this Lifter Roller trashed doesn't make any sense at all. Heads are good, Valve Springs are good.
Only thing that comes to mind is a Spring floated and beat the Lifter, but the Exhaust Valves are lighter so that is highly unlikely IMO.
Hopefully some of the more experienced guys here can shed some light on this cause I'm just as curious.
Old 10-13-2012, 08:51 AM
Old Geezer's Avatar
Looks like the rest of the lifters I see in the first pic, are trash, also. Look to be damaged out near the edge of the roller??
Old 10-13-2012, 09:00 AM
redbird555's Avatar
this^^ it looks like something is amiss with all the lifters? you say oil psi was fine during tuning and driving? its just odd to have almost universal damage like that and point to just one faulty part...
Old 10-13-2012, 09:37 AM
chrisfrost's Avatar
Lifter/ camshaft relationship/ geometry is something that is very precise so it can easily be off enough to cause You're problem and not be detected with the human eye or touch . This is 1 area of an engine rebuild that "We don't really get to "check" against real factory specs . It would be nice if the equipment to check these specs were affordable for You n I ,,,,,,,,,but ????
Old 10-13-2012, 10:23 AM
Yes all my oil psi was great until the bearing started to go. 45psi on hot idle and when driving it was 60+. These lifters were brand new too. Also, our lifter preload was within limits.
The lifter shown in the pic was the only one with damage to the sides.
Old 10-13-2012, 11:44 AM
kossuth's Avatar
Curious as to what cam your were running.
Old 10-13-2012, 12:03 PM
EPS cam 226/234 .598/.604 113+2
Old 10-17-2012, 07:27 PM
Got in contact with John at Tx Speed. Great guy. He is getting in contact with GM about the part and seeing what they can do. Hopefully he will give me some good news.
Old 10-17-2012, 08:46 PM
badazz81z28's Avatar
Yeah...All the other lifters look trashed too...I would NOT blame TSP...Its not like they make the LS7 lifters...Maybe not enough spring pressure and the lifters were bouncing on the cam?
Old 10-17-2012, 09:02 PM
elephantrider's Avatar
yikes. i just put new ls7 lifters in as well.
Old 10-17-2012, 09:15 PM
im running texas speed heads too. ported 5.3's with their .650 springs
Old 10-17-2012, 10:16 PM
CHADsterss's Avatar
The lifter may have spun in its tray.
Old 10-18-2012, 01:00 AM
the_merv's Avatar
We checked them, they were good.
Old 10-18-2012, 07:43 AM
Camaroo1's Avatar
1st thing is the idea that the lifter came apart and somehow damaged the bearing. Can't happen....nothing could get past the oil filter to damage the bearing. Why don't you post up all the details of this build, was the block used or dipped and properly cleaned? Those lifters look like they were run dry or in dirt. Was the cam properly prelubed before assembly? Was the oil gallery opened up and cleaned?
Old 10-18-2012, 08:57 AM
the_merv's Avatar
Block was Vatted at the machine shop, new cam bearings. Cam was heavily lubed with assembly lube prior to insertion. Everything was lubricated.
Old 10-18-2012, 09:11 AM
obie86's Avatar
In picture #3 of the lifter bore. On the left side of the bore is there two hair line cracks? Or maybe I'm seeing something...
Quick Reply: Spun #1 rod bearing?
