L76 Intake on a LS1???
Old 10-13-2012, 10:11 AM
Evan G's Avatar
Default L76 Intake on a LS1???
Well the question explains its self, and no I'm not getting new heads. I just wanted to get better air flow and gain some HP. If does fit what adjustments would I have to make!?
Old 10-13-2012, 10:21 AM
96capricemgr's Avatar
Isn't the L76 a rectangle port intake. meaning it wont fit cathedral heads
Old 10-13-2012, 11:35 AM
kinglt-1's Avatar
Yep...
Old 10-13-2012, 11:39 AM
lemons12's Avatar
If you aren't getting a 4" bore with rectangular heads on top of it, you aren't running that intake.
Ls6 or FAST are your two main options.
Old 10-13-2012, 11:40 AM
ls1ya's Avatar
A rectangular port intake is not going to work on cathedral heads
Old 10-13-2012, 03:46 PM
Sales1@Texas-speed's Avatar
Like everyone else mentioned this intake will not work on your stock LS1 heads.
Old 10-14-2012, 03:43 PM
Evan G's Avatar
Thanks Guys, Now after doing a little diggin I've narrowed it down. Ws6store sells both F.A.S.T. 92mm & 102mm all together with a fuel rails and throttle body its $1699. However they also sell the BBK intake w/ 85mm throttle body & fule rails for $980
Which one is better?
Is the F.A.S.T. set up worth the price?
Where can I find both these brands used? didn't have any luck on ebaymotors or google.
Old 10-14-2012, 03:58 PM
jonisalex's Avatar
If I remember correctly the BBK's horsepower/torque increase was only a tad better than going over to the ls6 manifold (given you dont have one).
Old 10-14-2012, 04:20 PM
lemons12's Avatar
You have so many mods you should address before dropping that kind of coin on an intake.
Ls6/ported TB will take you a long way. (roughly 375$ and milar gains as the BBK setup)
You can find any of those intakes on a regular basis in the classifieds.
Quick Reply: L76 Intake on a LS1???
