Cam specs????
Old 10-16-2012, 08:26 PM
zrmurcer's Avatar
Default Cam specs????
I have a 1998 trans am that I just tore the motor down on...I tryed looking the cam grind number up but couldn't find anything...
The grind number is. 3727R/3730R HR 114
If anyone could help me I would really appreciate it..
Old 10-16-2012, 08:40 PM
A.R. Shale Targa's Avatar
check the Comp Cams catalogue....they use the four digit system to identify
lobe profiles
Old 10-16-2012, 08:52 PM
zrmurcer's Avatar
I will look into that...although i am a novice on reading cam specs
Old 10-16-2012, 08:54 PM
David_viny's Avatar
234/240 .598/.609 114
Old 10-16-2012, 08:55 PM
zrmurcer's Avatar
Man i appreciate that....but how did you find that out
Old 10-16-2012, 09:01 PM
David_viny's Avatar
No problem, I have searched several times camshaft stuff so I knew right where to go.
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
Page 18 shows your lobe numbers
Old 10-16-2012, 09:09 PM
zrmurcer's Avatar
Thanks man....i just down loaded that pdf
Old 10-16-2012, 10:04 PM
zrmurcer's Avatar
If those are the correct numbers, which I completely believe that you know your stuff...what stall would be reccomended....i have a 3000-3200 circle d...
Quick Reply: Cam specs????
