Valve Spring Compressor HELP
Old 10-19-2012, 08:34 PM
bp m1009's Avatar
Default Valve Spring Compressor HELP
HELP! does anyone have a valve spring compressor that theyd be willing to let me borrow in NJ? or does anyone know where i could buy a good one locally? i have a cheap harbor freight one that wont work on my duel springs and i need a good tool. i have the project already started so im trying to find something local by tomorrow or sunday. any help would be greatly appreciated!
Old 10-20-2012, 11:11 AM
vettenuts's Avatar
I hope you are not try to use this, if so the springs you worked on should probably be replaced.
Old 10-20-2012, 07:22 PM
Hotrod350's Avatar
Oreillys normally rents them out. Mine does
Old 10-20-2012, 07:27 PM
bp m1009's Avatar
sadly yes i was trying to use that kind. why would i have to replace the springs now? im ordering the crane tool tonight
Old 10-20-2012, 08:05 PM
outkast6991's Avatar
Any nicks or scratches on the springs can be a failure point
Old 10-21-2012, 01:12 AM
bp m1009's Avatar
i was only able to get 2 on and their fine. what tool do you think i should go with, comp, crane, or trick flow?
Old 10-21-2012, 01:34 AM
silversweetZ's Avatar
I borrowed this from a friend http://www.summitracing.com/parts/WMR-W89409/ and it worked like a champ. KD tools make one similar for $8 cheaper. Don't get a flimsy one. For double springs you need one that they use for diesels and such. Took me 15 min to install them.
Travis
Old 10-21-2012, 10:24 AM
slamminjim's Avatar
I just use a crowbar type valve spring compressor from o'reilys. Its like $10.
I just use a water pump bolt with wd-40 on it and a 3/4 shallow socket as a spacer between said tool and bolt with flat washer. Works like a charm. Just put a rag between tool and gasket face of the head to keep from knicking it up. Hope this helps.
Old 10-21-2012, 12:12 PM
bp m1009's Avatar
im doing it in car on a 4th gen, theres no room for that...
Old 10-21-2012, 12:21 PM
slamminjim's Avatar
I used in car. You cut the handle off. Leave about 3 or 4 inches.
Worked no problems. There are easier tools that make the job faster. I just didn't want to spend $100 on a tool. Good luck.
Old 10-21-2012, 04:17 PM
bp m1009's Avatar
damn. well i just spent $80 on the trick flow tool. it will make my life a lot easier and ill be able to do 2 at once so thats a plus
Old 10-22-2012, 04:30 AM
vettenuts's Avatar
Exactly, those spring on which the "claw" tool was used should be replaced to prevent a failure down the road.
Quick Reply: Valve Spring Compressor HELP
