Ls1 vs lq4 crank
Old 10-23-2012, 06:40 PM
dkiller2135's Avatar
Default Ls1 vs lq4 crank
these are the same stroke right. Are the rods the same dementions. I'm planning on using the lq4 rods with a regrind ls1 crank. And the polished lq4 in the aluminum ls1 block. The rear seal area of the lq4 crank is longer in a 99 and 00 but I'm not seeing any info on the rod caps. All the bearings I see look to fit all, but the rod caps seem tighter on the lq4 crank with ls1 rods vs vice versa.
Old 10-23-2012, 07:56 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Yes they are the same stroke and rod dimensions. The early ones were longer in the rear so look out for those.
Quick Reply: Ls1 vs lq4 crank
