Oil burning issue... pulled plugs with pics
So i pulled the plugs on cylinders 1, 3 and 5 last night. I did a compession test a while back and all was well. I had come to conclusions that #5 was giving me issues, but didnt have any hard evidence until now... i think. I have been having on going issues with my driver side collector lightly puffing blue smoke, mostly noticeable at idle. I suspected it to be damaged valve seals. Anyway this is what i got let me know what you guys think.
number 1
number 3
number 5
number 5 looked pretty bad being the wettest and blackest... looks like wet oil
number 1
number 3
number 5
I thought intake gaskets on lt1s and older engines would cause oil burning issues, but not with ls or mod motors with the valley cover there's no way for oil to get in. Do you know who sells just the viton valve seals by themselves? I think I just want to change out the seals on cylinder 5 since that looks to be the problem cylinder
Just go to autozone and get some seals for a 2002 camaro...they are felpro which is the oem supplier for GM's LS valve seals. They are the top hat design which is an improvement from earlier design...be careful though because the exhaust and intake seals are different seals, but are packaged seperate when you buy them.
There are ways to isolate this problem to a specific cause. If you thinks its valve seals take the car down a long grade with someone following you. Gear down so the engine is holding the car back as you coast down the hill. This will simulate high manifold vacuum which will try to pull oil past the intake guide seals. gear back up and hit the gas. If your follower sees a cloud of blue smoke you have seal or guide problems. Generally if its exhaust seals you would see smoke from oil burning out the exhaust but this happens after the combustion process which wouldn't leave evidence on the plugs. Rings smoke constantly but the worst on WOT. How many miles are on the motor? Are you running a high lift cam?
