Cam choice for 5.3 Carb in a light car
Old 10-31-2012, 05:46 PM
Lawhead's Avatar
Default Cam choice for 5.3 Carb in a light car
Well I've been on here asking about my fox body and picked it up today the car is
Car is
AJE K-member with A-Arms
Flaming River Manual rack
Coil over conversion
Steed Outer Tie rods w/ bump steer
Harwood 6'
8 point cage
Strange adjustable rear shocks
8.8 with 3.73 Ford racing gears
Welds
The Motor I got is a 5.3 out of a 2008 Suburban with 243 heads going to go carb with a Vic Jr and doing it cam only so now the question is what cam to go with I've seen the MS3/TH400 mustang on here but not sure if that cam is the best with the 243 heads or I can go more with those or less and will be an all out drag car with almost no street time so I want to build it for the track what do you guys think??
Old 10-31-2012, 06:48 PM
wildcamaro's Avatar
I've seen some good test results with the comp came lsr series cams for 5.3....when choosing you want a lower lsa like 110-112 since you are carbed...
Old 10-31-2012, 07:04 PM
jaywill's Avatar
Old 10-31-2012, 07:15 PM
Lawhead's Avatar
Originally Posted by jaywill
I see you're doing something similar lol?
Old 10-31-2012, 07:19 PM
jaywill's Avatar
i see you're doing something similar lol?[/quote
YES ! street & strip...
Old 10-31-2012, 07:26 PM
Lawhead's Avatar
Seeing as I have the firebird this is going to be a pretty much nothing but drag car and maybe go hurt some feelings on a sunday drive......
Old 10-31-2012, 08:02 PM
garygnu's Avatar
get a custom cam to match your gears and stall converter combo.
Old 10-31-2012, 08:24 PM
TyCZ28's Avatar
somthing on a 108-110 LSA would suit that car best...
Old 10-31-2012, 10:14 PM
A.R. Shale Targa's Avatar
I'd suggest calling EPS for something in the 230-238 range.....
Old 11-01-2012, 12:53 AM
TyCZ28's Avatar
England green Mayhem 2 on a 109 lsa not sure if it would even run... but if it did... LOOKOUT
Old 11-01-2012, 11:30 AM
Lawhead's Avatar
So something on a 110-112 lsa would be best?
Old 11-02-2012, 11:30 PM
Lawhead's Avatar
Emailed AI and PM'd Texas speed now lets see what they come up with!!
Old 11-02-2012, 11:43 PM
LilJohn's Avatar
Just worked out a spec for a friend of mines bracket racing S10.... 5400 stall, Glide with 4.10's...
228/234@ .050 on a 109+4 is the first one we are gonna try.
Aiming for a 6500-6700 shift point and the ability to zerox timeslips.
Old 11-03-2012, 08:55 AM
Lawhead's Avatar
I'm kind of stuck on what Intake I should go with having the stock 243s and the Stock bottom end though to stick with the Vic Jr or go for the RPM
Old 11-13-2012, 07:32 PM
team39763's Avatar
When will you have results on this? I am doing a similar build.
Old 11-13-2012, 08:22 PM
windmill's Avatar
im watchin too,,, this what mine run all stock
Old 11-14-2012, 02:38 AM
BottleFedZ346's Avatar
I had Martin @ Tick performance spec a custom cam for my carb'd 5.3 setup....(Awesome guy to deal with)
Just to give you an idea my specs are 231/240 617/589 112+4 lsa, should work very well with my setup!
Old 11-14-2012, 04:42 AM
Lawhead's Avatar
He also did mine! Check out my other thread for info
Quick Reply: Cam choice for 5.3 Carb in a light car
