TSP 231/236 vs fms F13
TSP 231/237 vs fms F13
The texes speed cam may be a little big for the 978 springs what do you all think of the f13 cam ?
If you get the F13 cam, will you get the 112 or 114? What is the horsepower difference in these two cams? Which one is more streetable or best strip/street cam? Sometime in the future I am heading toward a cam/head package. Any assistance will be appreciated.
Originally Posted by 1Fst98ta
thats a good question about the 112 and 114 .. i wouldnt mind having a smooter idle
!LS1 11 Second Club
The TSP 231/237 will probably be easier on springs than the FUTRAL cam, because the lobes on the TSP cam are softer, less aggressive lobes (comparable to about an XE lobe from what I've read). I'm even running Comp 918's on my setup.
As for the lift numbers, both cams are similar. And, because of its aggressive ramp rates, I wouldn't doubt it if the smaller FMS can outperform the larger TSP, but in the end the two cams mentioned will put down similar numbers and produce similar results, just with a different manner of doing so.
Originally Posted by foff667
geez you startin to sound like gomer hadnt even worked out the issues you had before and already are stepping up to a bigger cam hehe
!LS1 11 Second Club
The thing i am worried about is valve float , i think the 978 springs are strong enough for either of the cams
You'll be fine with either cam. Valve float shouldn't be an issue.
Gomer was telling me that the F13 has a significantly better idle quality than the TSP cam does, which I'm sure is due to the faster ramp rates on the F13. I'm kind of leaning toward the F13 myself, except that TSP is working on some new lobes with Lunati that sound promising. They're working on a 233/233 and a 233/239. Last I heard though they were working out some P/V clearance issues with the faster ramps.
Craig
Craig
Spanky can you show us proof of where the F13 out performs the 231.237?
Mr. Gomer dynoed 451rwhp with the 231.237 camshaft, last I heard he swapped electric water pump, ported throttle body, the f13, and installed bigger valves in his Patriot heads to redyno at 457rwhp. 6rwhp from all those mods doesn't tell me the cam regularly outperforms the 231.237... Is there other results that I'm missing?
I think both cams work really well & you can't go wrong with either choice!
PewterZ28
Originally Posted by SPANKY LS1
I am going with the F13. Even though it is a smaller cam than the 231/237, it seems to regularly outperform the larger TSP cam. Good luck, Shawn
LSX Mechanic
PewterZ28
PewterZ28
The performance POWER wise is going to be pretty close between the 2. As far as driveability, there isn't a comparison IMO. My cam drives completely like stock, ZERO surge, ZERO idle hunting, and I can lug the motor @ 1200 rpm's in 6th if I want to.
FMS has proven to have the best of both worlds. Power and reliability. I'll be sticking with them.
josh
Spanky can you show us proof of where the F13 out performs the 231.237? Mr. Gomer dynoed 451rwhp with the 231.237 camshaft, last I heard he swapped electric water pump, ported throttle body, the f13, and installed bigger valves in his Patriot heads to redyno at 457rwhp. 6rwhp from all those mods doesn't tell me the cam regularly outperforms the 231.237... Is there other results that I'm missing?
PewterZ28
PewterZ28
Shawn
LSX Mechanic
All things being equal, the FMS grinds WILL make more power. I've seen it done over and over again. Alan @ Futral uses different and more aggresive lobes than Comp XE-R cams.
I've ran 3 different cams in my car, 2 were XE-R's and the final being the FMS stick. You see which one I stuck with..
josh
josh
Gomer dynoed 474 rwhp with the F13, 451 with the 231/237 (which is a signifigantly bigger cam than the 231/237 fwiw). His results are found here. He gained ~23 rwhp with a ported TB (~5hp) and an EWP (~0-5 hp), so it appears that the smaller FMS cam gained 10-15rwhp over the larger 231/237. (Heads were not touched during these dynos, no bigger valves, no add'l porting, etc) Search for FMS cam-only dynos for more examples of stout numbers being put out by 228/228 and similar "small" cams that are available from FMS. Taking nothing away from the 231/237, it is a good cam. But if I can have better driveability, idle, and still produce equal or more power with a smaller cam, it is a no-brainer IMO.
Shawn
Shawn
