Touble Starting
Touble Starting
First off here is my mod list...
TrickFlow As Cast 220cc Cylinder Heads- 3.90 Bore
Fully Assembled Including .650 Lift Springs
Mill to Desired Compression-61cc
Hardened Pushrods
228/230 .588/.592 112 LSA Camshaft
Comp Trunion Kit
GM MLS Head Gaskets
ARP Head Bolts
FAST Intake Gaskets
Powerbond 25% Underdrive Pulley with Gates Belts/GM Bolt- F Body
Comp Drop In Hi Performance Lifters
Katech C5R Timing Chain
Melling Hi Volume Oil Pump for LS Engines
SVO 42# Fuel Injectors
Poly Motor Mounts
Ok heres the deal. After install I had my car dyno tuned. It ran pretty well at first but then it started to surge more and when you get on it in first gear around 2,000 rpm it shutters real bad until around 4,000 rpm and then it takes off. Well now it has alot of trouble starting. It will fire up but if I dont give it gas it will die. It does this for about 10 minutes then all of a sudden it starts up just like normal. Its very confusing and I really have no idea. Any help would be appreciated. Thanks!
Hardened Pushrods
Comp Trunion Kit
GM MLS Head Gaskets
ARP Head Bolts
FAST Intake Gaskets
Poly Motor Mounts
If it's stumbling and surging it most possibly would be the tune.... if you want to check your fuel pressure just for measure u need a fuel pressure tester and it will connect on the Schrader valve on the driver side fuel rail .. stock pressure I believe is 58-60psi , just flick the key on don't start it and it will prime the pump.
Id also just check the obvious/stupid things that sometimes seem like a big issues.Take a good look at the spark plugs/wires.Ive seen guys accidentally arc on header,loose wires etc that cause weird intermittent surging/stuttering.Plus it an easy free thing you can do for peace of mind.
Sounds to Me like an EGR or smog pump issue or possibly an evap-emissions issue . If You google checking EGR ,,,,there are you=tube vids ,,,,there are a few different poeple on there that show how to check those and other systems
