Head is coming off
Old 11-04-2012, 12:28 PM
sam23's Avatar
Default Head is coming off
So i have a bad water/coolent leak so i have to pull the head off.
https://ls1tech.com/forums/general-m...g-coolant.html
im thinking i should just pull the other head off and replace the both head gaskets since the car has about 140K miles, My question is what else should i replace while im already gonna have the heads off? not trying to do anything crazy i drive the car a lot and trying not to spend lots of cash.
Thanks
Old 11-04-2012, 12:56 PM
Ron_Stoppable's Avatar
Personally, depending on the mileage, i would replace the lifters and trays while your in there.
Old 11-04-2012, 12:59 PM
conan's Avatar
I would have the heads vacuum tested at a machine shop and have them shave a couple thousands off to make sure they seal to the block decks well. Throw in a new set of ls7 lifters and new trays while the heads are off. Some new Gm MLS gaskets, and I would pull the water pump off and do the gaskets while the coolant is out.
You also could get in to the timing cover and do a ls2 timing chain and oil pump but that's up to you on how far you want to get in to this motor.
Old 11-04-2012, 01:09 PM
Marc3.4V6's Avatar
comp cams trunion upgrade if it fits your budget. It just upgrades the bearings in your stock rocker arms to make them stronger.
Quick Reply: Head is coming off
