What is a stock LS1 Shortblock worth?
I'm considering options and trying to figure out what my stock shortblock is worth. It will need re-bearing/rings and will need a head stud thread repair on one bolt hole. Otherwise the shortblock will come with the balancer and a Cadillac pan. Has a good oil pump and limited use on the single row timing chain.
Thanks!
Mike
Thanks!
Mike
It doesn't need rings or rod bearings from what I saw under ispection, but I figured while you are there...
It's a 99 block with about 55Kmiles on it.
Mike
Mike
I live in south west PA and I sold an old ls1 as a bare block and crank after I had it hot tanked for 400$. I figure there is probably a better market for them elsewhere in the us.
