very small scars in cylinder bore
Old 11-11-2012, 01:55 PM
td1168's Avatar
Default very small scars in cylinder bore
I recently tore my ls1 down because of excessive blow-by. When I finally got the engine tore down number 8 cylinder had some cylinder pitting right above the top compression ring at BDC. I think the cylinder somehow had water sittting in it for a period of time and rusted the cylinder wall. I bought a set of 3.908" bore pistons from Mahle thinking the cylinder would clean up. Well my friend and I honed the cylinder block on his sunnen machine and I can still see a small vertical spot about a 1/4" vertically where the pitting was and you can pick at it with your fingernail. My friend said he wouldn't advise sleeving that cylinder now because it could cause distortion in the already finished cylinder next to it. I don't know if I'm just obsessing over something I shouldn't worry about. Any expert opinions about possible effects of just going ahead and leaving it alone would be appreciated.
Old 11-11-2012, 01:59 PM
Reher Morrison's Avatar
Default pic
Need pictures
Old 11-11-2012, 02:01 PM
td1168's Avatar
I figured that might help. I don't have any right this minute. I'll try to get a few and post them. Thanks for the response though.
Quick Reply: very small scars in cylinder bore
