Crank pulley trick?
Old 11-11-2012, 07:51 PM
dkiller2135's Avatar
Default Crank pulley trick?
I got my engine in the car but have trouble getting the balancer to fit on the crank. The bolt is too short to pull it on. Thought I'd ask before I waste time. I need the asseries and radiator then I can fire this beast off.
Old 11-11-2012, 07:53 PM
I8UR4RD's Avatar
this is what i did. ****** finally came off after a few hours of ******* with it. good luck.
Old 11-11-2012, 07:58 PM
Received 3,360 Likes on 2,078 Posts
No trick involved. To install this the correct way, you'll need an install tool.
OR, you can use an ARP bolt, which is longer, and use the bolt to pull the pulley on. You'll even probably have people on here tell you to simply use a block of wood, and a sledge hammer. I'd recommend you change the bolt either way, to an ARP. The factory bolt is supposedly TTY, but I've seen them reused over and over and over.
Old 11-11-2012, 08:36 PM
96capricemgr's Avatar
I have never R&R'd the pulley on an LS BUT the LT1 hubs are a press fit too and what I do to help get them on far enough to get the bolt engaged is to warm it up. I boil the hub in a pot of water because I figure it wont go over 212f that way and I am sure the timing cover seal can handle that temp. If you are quick you can then slide it on a ways enough that the bolt engages anyway.
Maybe some variation of this idea can help?
Old 11-11-2012, 09:41 PM
badazz81z28's Avatar
Don't mess around...Get the correct tool from HAWK. Its $50 but worth it!!! and you will not damage anything.
Your just asking for trouble even thinking about pulling it on with a bolt.
Old 11-11-2012, 10:00 PM
wildcamaro's Avatar
Arp bolt works great....also heating the balancer helps if you have trouble, too much heat and you will ruin crank seal so oil it to prevent...the easiest way by far is to make a tool out of 16x1.5mm rod stock with some nuts and washers...
Old 11-12-2012, 08:52 PM
CATDIESEL's Avatar
buy or make the tool....... dont try pulling it on with the bolt , it doesnt take much to damage the crank threads.
Old 11-12-2012, 09:14 PM
Thank men, I believe I will try to duplicate the Hawk tool. If I had ordered the Arp with the rod bolts I may have gambled on it but I think I'll be safe. I sure am ready to put this thing back into service.
Old 11-12-2012, 09:16 PM
Tx91z28's Avatar
holy **** people a hammer or use the crank bolt!?!?! get the tool, otherwise your asking for damage
Old 11-12-2012, 09:50 PM
wildcamaro's Avatar
Arp crank bolt is longer so it has more threads to distribute the load, not that big a deal, now the hammer is a problem lol
Old 11-12-2012, 09:55 PM
Pwebbz28's Avatar
If its a stock pulley, i use a little torch to heat it up around the 3 pulling prongs, and slide it all the way on..Then use my bolt and tighten it down. Aftermarket, youll need an installer.
ABQ99TA's Avatar
WOW you give good advice and then REALLY REALLY bad. DO NOT RE-USE THE CRANK BOLT
either buy the hawk tool or make a tool. It is assh***s that re-use crank bolts that screw other poeple over later down the road when they try and remove it. If you want to snap your crank bolt off in the snout of the crank go ahead and give it a try. Trust me spend the $50 on the hawk tool. It took me countless hours of drilling to get a re-used crank bolt out
THIS^^^^^^^^^^^
Old 11-12-2012, 10:02 PM
Zmg00camaross's Avatar
You can PayPal me 55 bucks and borrow my tool when I get it back I will PayPal you 50
Old 11-13-2012, 12:08 AM
AutomagicLS1's Avatar
heat it up some and use a board and hammer to pound it on
Old 11-13-2012, 03:47 AM
vettenuts's Avatar
You can make a tool for under $20. Don't use a bolt at all to pull it on, you are asking for problems either now or later if you have to remove. Those that have done this are lucky they didn't have an issue.
Old 11-13-2012, 07:12 AM
No heat and boards and hammers. Called thrust bearings I like to keep them. Ppl almost overcomplicate this. Install tool and be done the correct way. Have I done it the old bolt and drawn it on way yes when in a pinch just taken a risk. But if I am working out of my toolbox the install tool is in there and I use it.
Old 11-13-2012, 07:37 AM
Even if using a tool I might be inclined to heat it some, that way it easily slides on further before you have to start pressing it on with a tool.
Old 11-13-2012, 08:43 AM
The heat part don't bother me as much as a block of wood and a hammer. But mine still went on like butter with no heat
Old 11-13-2012, 05:49 PM
THIS^^^^^^^^^^^
What really bad advice did I give? I said to do this the CORRECT way, buy the install tool. And I also told the op to buy an arp bolt. You should re-read my post. Yes I was being sarcastic.
Old 11-13-2012, 06:02 PM
boostit5.3's Avatar
i cleaned both up real good, sprayed them with wd-40, then hammered the pully on with a block of wood and a BFH. it only has to go on a little bit to get the bolt started, and i didnt even really hit it that hard, just straight! i also re-used the factory bolt with no problems. just my experience though... some people dont have the funds to opt for the right tool i guess.
Quick Reply: Crank pulley trick?
