Xr265hr-15 with ls6 spring.
Old 11-12-2012, 07:31 AM
4door5g's Avatar
Default Xr265hr-15 with ls6 spring.
I got a 04 a4 gto. It has intake, pacesetter LT, catless mids, 05-06 cat back. I also have, but have not installed yet. A 2500 stall and plan to spray a 75 shot. But my question is can I use the xr265hr-15 in the car with the ls6 springs. The specs on the cam are 212-218 .558-.563 with 115 lsa. Keep in mind also this is my wifes car. And it usally gets driven like a g-mah owns it. It might get a run or 2 a month. also the car will retain the stock rev limiter, and shift points.
Old 11-12-2012, 07:33 AM
Tainted's Avatar
I think the ls6 springs will do, but why not opt for some beehve 918's or the like? They would for sure be a huge improvement over a stock spring and give you peace of mind.
Old 11-12-2012, 07:49 AM
4door5g's Avatar
i will be putting a set of spring and hardned push rods in after xmas and all that is over with. but i got to pull the radiator this week to replace it, and figured while im already half way to getting the cam out. why not go ahead and slap it in there.
Old 11-12-2012, 07:52 AM
Tainted's Avatar
you should just wait and do it all at once
Old 11-12-2012, 08:02 AM
4door5g's Avatar
im not pulling the whole front of the car apart twice. i have got to do the radiator this week so she can drive the car to work. i can always swap out the springs and pushrods way easyer then pulling the rad, condensor,bumper, etc to get the cam out. plus i dont want to spend the extra $100+ on fluids and freon twice. from the research i have done the ls6 spring should be fine aslong as i dont rev it past 6200. when i get the extra money ill throw some springs in it. and put a good dyno tune on it. but i really think ill be ok for the time being.
Old 11-12-2012, 08:40 AM
garygnu's Avatar
put the springs and push rods in now ,or don't rev it pass 3500 rpm.the ls6 springs are designed for different cam lobe ramps then the cam you want to install.never cut corners with a engine build ,especially with valve train parts.
Old 11-12-2012, 09:36 AM
4door5g's Avatar
theres a whole thread on perfomance truck about some one using that cam on yellow springs with a boosted motor. i mean i know its getting close on the ls6 springs but i dont think the things going to let loose as soon as i hit 4K lol but i could be wrong. i think im going to try my luck thow. this thing dosnt get beat on all that hard.
Old 12-05-2012, 07:53 AM
4door5g's Avatar
so just a quick update. just did my 1st oil change since the cam. motor is runing strong the ls6 springs are holding up great. i have beat on it several times with 0 problems. drove it to daytona for turky rod run. and have been driving it to work daily. it didnt blow up as soon as i hit 3k rpms lol and im sure it will be fine. i still plan to upgrade the spring and pushrods. but for the time being they are fine.
Old 12-06-2012, 04:18 PM
dirty_old_chevy's Avatar
I've ran those lobes in a 4.8 with comp pushrods and yellow springs. Didn't have a problem. They were actually the 216 and 220 duration lobes. Took it past 7000 rpms every time I drove it with no sign that they were not up to the task.
Old 12-06-2012, 07:19 PM
garygnu's Avatar
the engine won't blow up ,but you mite experience valve float which will effect power.test the valve springs to see if they can produce proper spring pressure.why spin a motor past peak hp of a mild cam ?frictional hp loss will get greater as rpms go up.I would not trust stock GM trunnion bearings at high rpms,or the stock gm rod bolts.
Old 12-06-2012, 07:31 PM
wildcamaro's Avatar
Just cause the yellow springs worked (for now) on that cam don't mean it's right...pushing a spring to the max over and over will eventually lead to a fatigue failure..
Old 12-07-2012, 08:11 AM
Surprisingly, it pulled pretty good up until 7200. With the 4l60, I shifted into 2nd gear around 7000-7100, or else it was a dog in early 2nd. It didn't make real good torque till it hit about 4000. I dunno, maybe comp cams ground it with a bunch of retard in it. (I never degreed it). I have since put comp 918's and 0.030 shims in it, because I'm going turbo.
Old 12-07-2012, 08:58 AM
Also, I did the 4l80 conversion with that setup and found 6500 to be a better 1-2 shift point, due to less rpm drop.
Old 12-07-2012, 09:16 AM
Gunslinger09's Avatar
This is the truth right here. The yellow GM springs are good to .550 lift on a fairly mild lobe. Even though the lift isn't much over .550 the ramp rates on that cams lobes will cause the spring to fatigue over time. I would replace them with Comp 918 or equivalent springs as zoo as I could if I were you.
Quick Reply: Xr265hr-15 with ls6 spring.
