If you had 500$ to spend on a Full Bolt on Car
I have a 99 formula m6 with full bolt ons, and a frost tune. Long tubes, cai , ory, catback, i have around 500$ to spend right now, what would you guys do next?
You want power or handling?
$500 worth of suspension bits (like springs and shocks) will make more of a difference than a little bit of power that say an LS6 intake will get ya. So I would go with that at this point, or save a few more bux and get a cam kit that will net you some real power.
Either save for cam/spring/push rod kit or nitrous. $500 is probably a smidgen short for either option though.
Depending on what your setup is and what you intend to do with the car maybe a stall and/or drag radials. We need more information to answer sensibly.
if you have a 99 car with stock hydraulics/clutch in it...i would purchase the needed hydraulics and a clutch kit if possible. esp if you put a sticky tire on it..you will need the aforementioned parts.
if you aren't interested in clutch stuff now...i would purchase a ram air kit (chrs1313 or equivalent) and some drag radials.
of if you don't want either of those. some 390 gears.
