Hissing while turning engine over by hand?
Old 11-16-2012, 12:36 AM
Ferocity02's Avatar
Default Hissing while turning engine over by hand?
Did some valve work tonight and noticed a hissing sound when turning the engine over by hand. Sounds like air leaking or something as if pressure is being released. After turning the motor lets say 20 degrees, it will hiss for 3-5 seconds. The hissing is coming from the driver side only near the rear. Passenger side was dead silent. It hisses even with all spark plugs on the driver side removed which I thought was weird. Driver side rockers on or off, it still hisses.
I probably did about 4 full crank rotations by hand and the hissing never stopped or lessened. It's like somehow pressure is building in the cylinders even though the plugs are out. The plugs were still in on the passenger side, but how could pressure over there make a noise on the rear driver's side?
I can't think of anything back here that would cause this sound. I've been trying to track down a metallic tapping sound around cylinders 5-7, same area where this sound is coming from. Perhaps they are related?
Old 11-16-2012, 12:56 AM
Ferocity02's Avatar
Just came up with a theory actually. The passenger side might just be sucking in air through the PCV valve, which is located as the back of the drivers side on a 5.3L. I shall investigate tomorrow.
Old 11-16-2012, 01:00 AM
trevmust's Avatar
answered your own question lol. HIGHFIVES ALL AROUND
Old 11-16-2012, 01:07 AM
Ferocity02's Avatar
It's the only thing I could think of.
Old 11-16-2012, 02:26 PM
Ferocity02's Avatar
Figured it out... wasn't the PCV. But rather the hissing sound caused by the air leaking past the rings on bank 2 was going through the block and coming out of the head on bank 1 where I had the valve cover remove. I pulled the valve cover on bank 2 and heard the same hissing sound
Old 11-17-2012, 08:01 PM
chrisfrost's Avatar
That's what I was thinkin ,,,,,,,,,,,,either that or maybe a snake wiggled it's way into You're engine ?????????,,,,,,,,,,he he jus kiddin
Old 04-23-2016, 02:31 AM
cmd1126's Avatar
I have the same issue. Is this normal if not how do I fix it?
Old 04-23-2016, 07:47 AM
bbond105's Avatar
normal
Old 04-23-2016, 08:24 AM
cmd1126's Avatar
My only difference is that my engine is a fresh rebuild and does not hiss when the plugs are pulled and hooking up the starter to a batter with jumper cables will not turn the engine over with the spark plugs in
Old 04-24-2016, 04:45 PM
cmd1126's Avatar
Unhappy
Help please!
Old 04-24-2016, 07:33 PM
bbond105's Avatar
It will not hiss with the spark plugs removed because the compression is going out the spark plug holes. Can you turn the crankshaft with some type of wrench? If the crankshaft rotates with not a lot of effort your starter is defective, your battery is weak or not fully charged or your jumper cables are too small.
Old 04-24-2016, 08:04 PM
Taxman20's Avatar
Its normal for the engine to "hiss" when the plugs are in it. ALL engines do this. Its the compressed air getting past the rings. Completely normal. Move along, nothing to see here.
Old 04-24-2016, 08:55 PM
Nickster 7's Avatar
Same happens when you turn over a small engine by hand. Have a 12HP Briggs on an old riding mower that does this.
Quick Reply: Hissing while turning engine over by hand?
