New style rear main install questions
Old 11-16-2012, 06:22 AM
1bad03snake's Avatar
Default New style rear main install questions
I installed my rear cover and new rear main last night. When I was tapping the new seal into the rear cover the plastic insert fell out. After looking at it for a few seconds it looked like I could slide the cover back in with no issues and install it. I put the cover over the crank and pushed it on and it the seal seams to be sitting on there fine. Has anyone else had this problem? I did not lube the seal face like the gm manual instructs. Did your seal leak after you got the car running?
Thanks for the help
Old 11-17-2012, 08:05 PM
chrisfrost's Avatar
Are You talking about the rear crankshaft seal calling it the rear main ? The rear main usually refers to the #5 crank main bearing .
Old 11-19-2012, 05:14 PM
JPH
JPH's Avatar
Thanks for the help
Borrow the GM LS rear seal tool from a local gm garage, leave the rear cover bolts loose while you install in dry.
Quick Reply: New style rear main install questions
