Ok quick question I have harpland sharp trying to make sure I'm doing this right wen installing each set of lifters I make sure each cylinder is tdc right?
Sorry, but I am confused. Are you asking about lifter installation or rocker installation? The type of rocker won't influence how the lifters get installed.
You never heard of using roller rockers instead of lifters? You get to really jack up the cam lift. when you multiply cam lift by 1.7 TWICE. That is probably why the PTV issues.
I was talking rocker install I heard you have to have each cylinder tdc when installing rocker on that cylinder... But I don't think that true I think my prs are to long
Technically you should, but plenty of people dont. How long are your pushrods? Also note most aftermarket cams have a smaller base circle so they require a longer than stock pushrod. Stock is 7.4 for reference.
I'm also using the ls7 lifters now I see there alittle taller the the stock ls1 I'm thinking it has to be but can't check til pr checker gets here... Or should I try doin each cylinder tdc and trying again
Oh my bad I see the title say lifters I meant rockers I was so pissed should of be running mixed up words
Figured it out rockers werent adjusted right plus cam was exhaust stroke 180 the cam no ptv problems no more thanks to martin from tick for the email write up
