Flycutting tool
Old 11-26-2012, 03:01 PM
M1SERY's Avatar
Arrow Flycutting tool
look for fly cutting tool where can i get one, and some information on how to do it
Old 11-26-2012, 03:06 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
What heads are you going to be running? Valve size can/will make a difference on which cutter(s) you will need!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 11-26-2012, 03:08 PM
slamminjim's Avatar
I have a Lindy tool I can rent you. Its for 2.02 1.57
Valves. Works for stock valves also.
Let me know. I can explain to you how to use it also
Over the phone or pm's
Old 11-26-2012, 05:15 PM
M1SERY's Avatar
a set of 215 tsp or there PRC Stage 2.5 5.3L CNC Ported Heads
the 5.3s r more n my price but with my cam think i have to cut my pistions 58 thousand gasket with 62cc is smallest i can go. correct my if i'm worng , like the comp. ratio to be 11
Old 11-26-2012, 05:18 PM
M1SERY's Avatar
thanks man will contact you have u done this before
Old 11-26-2012, 06:03 PM
slamminjim's Avatar
I cut mine .100
It was extremely easy and took less than an hour to do.
Old 11-26-2012, 07:25 PM
wildcamaro's Avatar
^^^wouldnt that be putting the pistons out of balance? The cuts don't look the same on each piston...did you do that with pistons in or out of the car?
Old 11-26-2012, 07:49 PM
slamminjim's Avatar
The pistons were cut installed in the block. You put the cutter in the head with piston at tdc.
The intake and exhaust contact the piston at different locations. That's why they are staggered.
Idk how much this would effect the balance.
Old 11-27-2012, 08:47 AM
Fastdriver1992's Avatar
i did this on my stock bottom end LS6, raced it for 2.5 years, spun to 7000rpms no problems
Old 11-27-2012, 09:23 AM
At the point someone is going to pull the rotating assembly after cutting pistons to balance it, most folks would have just put an aftermarket piston with valve reliefs in the short-block and called it a day. I'd say the vast majority do not re-balance after cutting the pistons...whether that's right or wrong in your book you must decide.
__________________
Old 11-28-2012, 11:41 AM
TT427's Avatar
This would also help put you into an overbalanced situation. Not necessarily a bad thing. 52% would be about the limit for a street driven car, it will smooth the higher RPMs some with no effect in the lower rpm. Go beyond that and you will feel a vibration in the lower revs. This probably not even 1% change in balance.
Quick Reply: Flycutting tool
