cheater cam??
cheater cam??
I have 2002 trans am A4 with long tubes, borla cb, lid and tune. I also bought some 243 heads but haven't installed them yet. I was thinking of buying the V3 cheater but don't know if I should. What cam do u all recommend? I would like for it to be a sleeper but would consider others. Thanks
This cam would work real well with the 243s and be completely stealthy.
Stock like idle and driving manners.
http://www.engpwrsys.com/index.php?a...od&productId=5
Even though it's grindedered by Comp.........
You don't need the wide split, go with a single pattern or mild split cam.
Here's some good examples: 218/222 115+2, 220/220 115lsa+3, 220/224 116lsa+3, or a 222/222 116lsa+3, or 222/226 117lsa+4. All of these would have -10* overlap.
Martin at Tick can get you the right cam for your needs/wants. Now if you want a shelf grind that will also work good then get a TSP 220/220 with a 115lsa.
