Need help finding a crank pulley removal tool
Hey guys, I ran into an issue yesterday installing my cam. I went to oriellys and got a 6" 3 jaw pulley removal tool .THAT DIDNT WORK!! Anyone kno where I can find the correct tool ?
Autozone 3 jaw puller works like a charm, although at first I was trying to pull from the outside of the pulley like a tard, the three notches on the inner hub of the crank pulley fit perfect with 3 jaw puller...just make sure you get the "big" 3 jaw and not the small one bc they have two different ones
Ok cool I got another question for u guys !! I got a 5.3 lm7 and when I was taking my intake off and I broke a sensor? I'm not sure what it is but it's to the right of the Camhaft position sensor. It has a 1 or 2 prong plug-in and the top of the sensor and it's plastic ( best way I can describe it )
http://www.autozone.com/autozone/acc...er=231202_0_0_
There ya go...they also got a gm 1-1 1/4 oil pressure sensor socket even though you really don't need it if you have a deep well socket...
If the autozone puller doesn't work for you, it doesn't work for you. No amount of re-trying will get it to work. I used this on my LS2 after breaking 3 rented pullers. Came off like a knife through butter:
http://www.amazon.com/OTC-6667-Harmo.../dp/B000P6UT2I
