Cam install, please review my parts
Old 12-02-2012, 05:38 PM
tyler99's Avatar
Default Cam install, please review my parts
OK, basically I'm ready to order a cam package and a couple other things, just wondering if I have picked out any wrong items.
For the cam, I am going with the MS4 with dual valve springs/pushrods.
Other things I am wanting would be:
GM Replacement LS7 Lifters (https://texas-speed.com/p-309-gm-rep...7-lifters.aspx)
GM LS2 & Newer Style Timing Chain (https://texas-speed.com/p-414-gm-ls2...ing-chain.aspx)
Basic Camshaft Bolt & Gasket Kit (https://texas-speed.com/p-169-basic-...asket-kit.aspx)
Melling High Volume Oil Pump (https://texas-speed.com/p-109-mellin...-oil-pump.aspx)
GM Oil Pump O-Ring (https://texas-speed.com/p-112-gm-oil-pump-o-ring.aspx)
Are all these parts good options, that will fit into place without any mods? Am I missing anything?
Any help would be awesome, I would love to order everything at once to cut shipping costs.
Thanks!
Old 12-02-2012, 05:40 PM
alexus6798's Avatar
What type of car? What are your goals for it? Transmission type?
Old 12-02-2012, 05:49 PM
tyler99's Avatar
Sorry, I was just getting ready to edit, but its a 98 camaro, M6
Its not a daily driver, just a fun car on nice weekends, take it to the track 2 times a year, and I would love to see high 11's with a cam only set up and ive seen it done before with the MS4.
It ran a 12.9 with exhaust only a few weeks ago.
Old 12-02-2012, 05:54 PM
alexus6798's Avatar
That's alot of cam. You will need gears with that and a good rearend to do that cam only. I would love for my car to have that MS4 sound but I want mine to be fun for around town driving. You will also most likely have to spin your motor pretty high and them 98 rod bolts might not like that.
Old 12-02-2012, 05:58 PM
Sales1@Texas-speed's Avatar
If your wanting an aggressive setup the MS4 is definitely a good choice. Your list looks good but I would swap the high volume pump for a high pressure one and you won't need a GM o-ring as the melling pump comes with a new one. Also feel free to give me a call Ill be happy to go over everything with you and make sure you get the right parts the first time around.
Old 12-02-2012, 06:13 PM
tyler99's Avatar
Thanks guys! From what I take it then the parts I have listed are what I will need if I take this route.
Old 12-02-2012, 06:15 PM
PM replied to.
Old 12-02-2012, 06:20 PM
ABQ99TA's Avatar
If you are going to do lifters you should do heads also. To much work and $ on bolts and gaskets to put stock heads back on.
Old 12-02-2012, 06:27 PM
Turd Gen Guy
1nasty86's Avatar
throw a set of stock 243/799 heads on it and pick up another 15-25 hp....
Old 12-02-2012, 08:44 PM
tyler99's Avatar
as much as I would like to do heads, I just don't have it in me to spend that much more money. Heads will come someday, possibly next Christmas. My current clutch is shot so I already have to factor in 500+ for that as well. But heads will come someday.
Old 12-02-2012, 08:48 PM
badazz81z28's Avatar
Hold off on the lifters then....
Super Hulk Smash
JakeFusion's Avatar
Lifters aren't a necessity if you aren't pulling the heads. Just adds a lot of work.
Also, you don't need the o-ring. The Melling comes with two different ones (one for the iron block and one for our cars).
Old 12-02-2012, 08:53 PM
tyler99's Avatar
ohh sorry, should have mentioned that I have a ticking lifter which is the only reason I'm changing lifters
Old 12-02-2012, 08:55 PM
tyler99's Avatar
thanks! Tsp also stopped me from adding the o-ring and told me to switch oil pumps, one of less money so it made me happy lol
Old 12-02-2012, 09:50 PM
98WS6Hville's Avatar
Even a pair of 243 heads would help significantly. You can buy those used for around 500 bucks and ensure roughly roughly around 20 horsepower. It's going to help that cam put out more power. This is a setup that I went with for my current build: TSP 224R Cam, 243 Heads, and full TSP Exhaust.
*Cam: TSP 224R
*Heads: 243 Heads
*Exhaust: TSP 1-7/8" LTH, TSP Y-Pipe, Already had aftermarket mufflers with car.
*LS7 Lifters (12499225) x1
*LS2 Lifter Guide Trays (12595365) x4
*Ported Melling Oil Pump (SD0295C) x1 [mine came with gaskets]
*LS2 Timing Chain (12586482) x1
*LS2 Head Gasket (12589227) x2
*Cylinder Head Bolt Kit (12498545) x2
*Texas-Speed Camshaft Bolt and Gasket Kit (28-CamGskKit) x1
[Kit includes:Cometic Timing Cover Gasket, Cometic Front Crankshaft Seal, Cometic Water Pump Gaskets, GM Harmonic Balancer Bolt]
*Brian Tooley Max Pressure Spring Kit .565" (SK002) x1
*LS Chromoly Pushrods (PR7400312) [comes in 16's] x1
*Assembly Lube
*Iridium NGK Spark Plugs
*LS1 Spark Plug Wires [changed due to high mileage]
*Rocker Arms [if a high mileage ride or high lift cam]
*LS1 Coil Relocation Kit
*Center bolt valve covers
Last 2 listed are because of the '98 model f-body.
*A tool to compress the valve springs
*Be prepared to be having to buy things online and for this to take a while. There have been things that I have had to get here and there. If this is your first time doing this, things will probably break. For instance, I accidentally ripped one of my knock sensors (yikes) and had to get pigtails and the appropriate knock sensor.
http://www.ls1howto.com/ < --- GOLD
Best of luck. Just be patient. This process takes a while.
Old 12-02-2012, 09:55 PM
chevybayboy's Avatar
Coolant bypass gaskets... A lot of people talked me out of the ms4 cam as well that's a big cam you might haave to fly cut your pistons ... I like the way that cam sounds but you gotta.spin the motor to high you might and well do rod bolts with that cam
Old 12-02-2012, 10:00 PM
And 250 for mail tune or 500 for dyno
Old 12-03-2012, 12:28 AM
Turd Gen Guy
1nasty86's Avatar
Look at tick performance's cam package deal.... I have a friend with 243 heads, ls6 intake and a cam similar to Martin's 231/238 on a 112 make 419/396 at the tires....
Old 12-03-2012, 03:57 PM
tyler99's Avatar
I'm just pretty well set on the MS4 cam. I'm just doing a little more install research to make sure ive got everything and the ***** to tell my parents that their cars are going to be sitting outside for awhile
Quick Reply: Cam install, please review my parts
