Another LQ9 Build, Input Needed.
After reading all the great 6.0 builds I am going to jump on the wagon . With that said, I would like to get some opinions on what I should or shouldn't do. I am wanting to transplant a 6.0 into my 95 Firechicken when complete. It will mainly be used for Street/Show and the occasional track trip.
So far I have a 2005 LQ9 from a Cadillac Escalade with 95,xxx miles. I have not touched this engine since purchasing from the salvage yard. I would like to make at least 450rwhp(more would be even better ). I would like to think this is possible with what I have, if not, then build on to what I have.
With all the setups floating around on the net, I don't know which way to go with it. This is were this thread comes in.........
Your input is appreciated. Thank you in advance.
The LS6 intake usually gets replaced with a FAST 92 or 102 by the time they
reach your desired power level. Check this link for your head upgrade.......
http://www.advancedinduction.com/LSX...inderHeads.php
This guy can match you a cam or you can try EPS or TICK for a healthy grind
http://www.engpwrsys.com/index.php?a...ctId=6......or.....
http://www.tickperformance.com/tick-...r-ls2-engines/
Thanks for the replies guys! I want to get all my ducks in a row before I get started. Like anyone, I want to build it with the least amount of money in it to get the power I am looking for. But on the other hand, if I need to spend it I will.
The more threads I read from others builds the more confused I am.
