stored car and aftermarket springs
Hi,
I would like to know if car is stored for like a year, should I worry about springs losing pressure as some of them will remain pressed under the cover? or just harmonics/wear from normal use does that?
Springs are dual, PRC's temporary with stock cam.
Thanks
Thanks
People do it all the time with NO issues. Some will ocassionally rotate the engine over to get change valve opening/closings. You could just pop the valve covers off and lossen ALL the rockers up so there NO tension at all.
I don't worry about this because I store my car in a "CARBAG". The car is zipped into the bag with dessicant to keep it dry. If I didn't, the humidity where I live would wreck a lot of things and the aluminum parts would look like crap. Cold damp salt air is tough on the car over the winter and especially in early spring.
