ls1 cylinder bore question
Old 12-05-2012, 12:28 PM
ckpitt55's Avatar
Default ls1 cylinder bore question
While I've got my shortblock apart I'm measuring my cylinder bores for wear. I've got some questions about some of the tolerances.
I printed out the stickied spec sheet, and have the taper spec for the "thrust side" of the bore - is the thrust side the direction of the bore perpendicular to the length of the block? (i.e. from the side, pointing towards the crank). Also, is there an out-of-roundness spec for the bores? I'm going to take my measurements again with a better indicator and with the heads/main caps torqued down, but right now in its relaxed state, it looks like my max o-o-R ranges from 0.001-0.002" cylinder to cylinder. Does anyone happen to know what is acceptable before a rebore and/or rehone is necessary?
Old 12-05-2012, 01:08 PM
KCS
Moderator
KCS's Avatar
The cylinder head is going to change the bore dimensions. You may be able to torque the head on and drop the bore gauge in from the bottom.
Old 12-05-2012, 04:44 PM
ckpitt55's Avatar
that's what I was going to do. any idea on an acceptable roundness?
Quick Reply: ls1 cylinder bore question
