Marks on cylinder wall, valves too big?
Pulled apart the engine yesterday to investigate a tapping noise that's been annoying me for awhile now. On cylinders 5 and 7, at the very top, there is a mark/groove that's been worn into the cylinder wall. It looks almost like the exhaust valve was touching it, but the valves didn't have any visible wear. The motor is a stock bore 5.3L, with 799 heads. The intake valves are 2.00", and it had six 1.59" exhaust valves and two 1.55" exhaust valves because they jackass I bought them from put in the wrong valves. I don't think these valves are too big for the cylinder though. NONE of the other cylinders have this mark, just 5 and 7. Luckily, the mark is just above where the rings get to so I hope there is no ring damage. Cylinder walls look money.
On first start up there was a screeching/tapping sound that started after about 5 minutes, and only lasted on for the first drive. Then a tapping noise began a hundred miles later or so that sounded like a lifter, hence the tear down I'm doing right now.
#7:
#5:
#7:
#5:
Well, the valves were the wrong size, 1.59 instead of 1.55. Once I get the right valves in there it should be fine. But I didn't know 2.00 and 1.59 were too big for 5.3l bore. And its weird that only these two cylinders had marks. Perhaps its due to minute errors in casting tolerance and mahining tolerance.
